Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 07-15-2016, 10:40 PM   #21
bern
2004 ION-2 Sedan
Default Re: 2007 Greenline charging issue
You need to turn on the ignition to program so I don't theirs a problem with starting and trying it out . don't do this to an IPC or BCM that store milage.
Battery Energy Control Module Programming and Setup
If the generator battery disconnect control module is replaced or has to be reprogrammed, it must be programmed using the service programming system (SPS). Refer to Service Programming System (SPS).
this may be different if it is an aftermarket part
Add to bern's Reputation
Old 07-16-2016, 08:42 AM   #22
Loktai
Loktai is on a distinguished road
Alrighty.. I am just waiting on the jumper harness at this
point so the harness will reach .. and we'll see where that gets me.
By now I have spares for every part of the
hybrid system, excluding the sgcm since it was
supposedly bad when replaced and the removed
part was treated poorly (thrown in a box)... so
with luck I have everything needed outside of
programming to get this thing to behave.
Thanks again for your input, helps a lot with my
sanity level.
Add to Loktai's Reputation
Rate the quality of this post and help Loktai reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Loktai is offline   Reply With Quote
Old 07-20-2016, 04:37 PM   #23
Loktai
I've replaced my BECM, and I started up and now I'm getting 14+ volts and it's charging the battery, success it's drivable. I am having an issue with the hybrid system and getting code p1a62. I can drive and you will see the charge/assist acting normally and you can feel it helping, auto stop was working after driving for a while... then Ice had this issue where the charge gauge begins only moving about 1-8th of the way left, and never to the right, stopping and starting the car stopped that and brought it back to normal then I got a code p1a62, the gauge stopped working at all, but I still had the ECo light and was making 14v, so still drivable just n hybrid function. I'm looking into this now, figured I'd post in case someone had input. I have not had the car programmed yet, I replaced the BECM and everything was working as stated.
2007 Vue Greenline - Troubleshoot hybrid mcentyre Vue Green Line 6 07-13-2016 11:13 PM
2007 Vue Greenline Drive Belt mcentyre Vue Green Line 15 11-28-2011 03:54 PM
2007 Vue GreenLine mileage, etc. ski4ever Vue Green Line 4 03-15-2010 03:16 PM
2007 Aura charging issue 2007aura Aura General 15 09-16-2008 12:07 PM
2007 Greenline possible service issues brutedawg20 Vue Green Line 2 12-03-2007 01:03 PM
