Old 06-11-2016, 10:46 PM   #1
Maghoul
Maghoul is on a distinguished road
2008 VUE 3.6L
Default 2008 Saturn Vue XR new radio
Hello, I installed a Pioneer AVH-280 BT in my Vue. It requires both the PAC SWI-CP5 and the PAC OS5 wiring harnesses. I also added the associated backup camera. I hooked it up in accordance with instructions, but have a couple of issues.
1. The volume is not loud enough
2. The light behind the exterior lighting and hazard light remains lit, which is using up the battery.
3. The chime isn't working.
I think I got over zealous in hooking up wires, which may explain why #2 is an issue. Has anyone had a similar experience with associated fix? I think the culprit is I hooked up the dimmer wire, whereas I don't think my vue' harness has the same wire. Thanks.
Add to Maghoul's Reputation
Rate the quality of this post and help Maghoul reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maghoul is offline   Reply With Quote
Old 06-14-2016, 03:05 PM   #2
Maghoul
2008 VUE 3.6L
Default Re: 2008 Saturn Vue XR new radio
I figured out 1 and 3. It was human error, I hooked into the amplified side of the OS-5 instead of the non-amplified side. I'm still seeing the light behind the exterior no the hazard and light switch illuminated. I totally unhooked the radio and it is still illuminated. Does anyone have any ideas what would cause this?
Old 06-14-2016, 04:00 PM   #3
Maghoul
2008 VUE 3.6L
If anyone looks at this, I guess the backlighting is a feature of the car per thread 108297.
Installing new radio in 2008 saturn astra saturnquestion Astra General 3 12-12-2014 01:35 PM
Request for a Saturn vue 2008 radio wiring diagram Peter0321 Vue General 3 11-24-2014 04:51 PM
Upgrading Radio in 2008 Vue nuevue Vue Mods 0 01-31-2011 02:03 PM
2008 saturn astra radio wont shut off after car door opens saturncoupe25 Astra General 11 11-04-2008 07:27 AM
removing the radio on a 2008 Saturn VUE pico26 2008 Vue 11 09-01-2007 09:17 AM
