Old 06-10-2016, 11:01 AM   #1
Fattage
Fattage is on a distinguished road
Default Gas pours out of Evap Canister
I have a 98 Saturn SL2. When I go to the pump it takes 10 minutes to fill the tank because gas splashes back out at me if I fill to quickly. I checked the Evap Canister under the rear wheel drivers side. I hooked up the canister because it wasn't working (no electricity and stuck in the closed position) I ended up replacing it (twice) and fixing the wiring. Now when I started it up the solenoid clicks closes the valve and everything is good. Then When I stop and turn off the car (opening the solenoid) Gas just starts pouring out of the canister so I run to the drivers seat and turn it to the on position to close it, open the gas tank lid, let a large amount of air out of the tank, close the gas tank lid, then take me keys out and it stops pouring gas.
I've been doing some research and it looks like most cars have two lines one for fuel and one for evaporation but my canister looks like it only has one place to put a line in. I have tried finding a diagram of how this system is supposed to work but can't find anything.
For the time being I have plugged the fuel line to the solenoid and left the solenoid plugged in so it still opens and closes (so I get no check engine light) and it's been like that for awhile now but I'm tired of having an inaccurate fuel gauge and taking forever to fill the tank. Do you know what I need to do? Thank you for any help you can give. If you want pictures I can do that too.
I attached a picture of what the solenoid looks like.
Add to Fattage's Reputation
Rate the quality of this post and help Fattage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fattage is offline   Reply With Quote
Old 06-10-2016, 11:09 AM   #2
billysvue
Default Re: Gas pours out of Evap Canister
Have you inspected the lines from the fill to the tank?
Gas splash back indicates improper venting( to me)...
YOU don't top the tank off, ever, right?
WHen you replaced the cannister(twice) did that include the vent valve solenoid?
OR at least an operational inspection of same?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-10-2016, 11:24 AM   #3
Fattage
I have not checked the fuel line to the tank yet, thought it was more of a venting issue myself which is why I looked at the solenoid.
The charcoal canister and Solenoid come in one package so yes I replaced the solenoid both times.
I never top off the tank except for the fact that it is hard to tell when the tank is full since it isn't venting properly. I have replaced the solenoid and charcoal canister when the tank was about half full and I started it drove around the block and parked and then it pour out of the solenoid again immediately after.
I just don't know how the tank system is supposed to get rid of the air as I'm filling it since that is the most likely problem. I though it was the solenoid that was supposed to do that but something isn't working right.
Old 06-10-2016, 12:06 PM   #4
Does this help?
Old 06-10-2016, 12:50 PM   #5
billysvue
#8... the "fill limit vent valve" for the gas tank seems very suspect.
I believe the vent valve for the cannister has an entirely different purpose( to vent when "purge" is active)
( from the previous pdf's)
"The components that make up the enhanced evaporative emission system consist of the following:
1. EVAP canister vent solenoid, located on the upper end of the fuel filler pipe just behind the left rear
wheelhouse liner
2. Fuel tank
3. Evaporative emission system canister, nested on the top of the fuel tank at the left, rear corner
4. Fuel tank pressure sensor, inserted on the top of the right, rear portion of the fuel tank
5. System fuel lines and hoses
6. Evaporative system service diagnostic port, located in the canister purge line, under the driver's side
floorpan behind the left front wheel
7. Canister purge solenoid, mounted below the intake manifold on the side of the cylinder block, toward the
rear of the block
ImportantThis component is not part of the enhanced EVAP, but is part of the ORVR. Refer to Theory of
Operation * Fuel Filling and ORVR.
8. Fill limit vent valve (FLVV), located on top of the tank, between the canister and the pump module"
'17 Suby Forester
Old 06-11-2016, 09:39 AM   #6
floridasl22002
floridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to behold
Fattage..... can i just point out that you have an SL2. You have posted in the L Series section. You should have posted in the S Series section. You are getting advice from L series owners. If you repost in the correct section, you will get far more responses more relevant to your specific vehicle.
1996 SC2 Evap Canister rp1138 S-Series Tech 1 07-24-2013 09:18 PM
EVAP Canister Damaged blackeagle1 S-Series Tech 3 10-18-2012 12:37 PM
Where is EVAP canister? joemac53 2008 Vue 2 01-17-2012 08:36 PM
EVAP Canister Swap saturndriver59 S-Series Tech 3 01-30-2009 11:16 PM
01 SL1 Evap Canister Dojober belloc S-Series Tech 11 02-26-2008 03:32 PM
