Old 06-10-2016, 10:17 AM   #1
cdog999
cdog999 is on a distinguished road
Default 2005 Ion P1516
Check engine light turned on this morning and checked the code and got P1516. Anyone have any recommendations on a quick way to resolve?
Just got the car a month ago, about 71K miles on it. Drives well, but noticed that it appears to get slightly less MPG than expected (not huge, but definitely less than my 96 SL2 got).
Add to cdog999's Reputation
Rate the quality of this post and help cdog999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cdog999 is offline   Reply With Quote
Old 06-10-2016, 10:56 AM   #2
Default Re: 2005 Ion P1516
DTC P1516 Throttle Actuator control (TAC) Module Throttle Actuator Position Performance
Drive by wire systems use a computer to command throttle open and close according to pedal position. Electronic throttle, engine computer, and electric throttle. You can see how throttle operates by having someone press the gas pedal while you watch throttle open and close (ignition on engine off). Throttle cleaning may help. Spark plugs replaced at recommended mileage intervals (owners manual)? Dirty air filter?
Old 06-10-2016, 10:58 AM   #3
billysvue
what others have posted
CHeck first result/thread- at the end
What's the maintenance history? WHAt have you done while owner? PLan on doing?https://cse.google.com/cse?cx=partne....q=p1516%20ion
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-11-2016, 10:25 PM   #4
cdog999
Thanks for the advice. I just got the 2005 Ion a month ago . Its at 71K miles. I became very familiar with my 96 SL2 which I owned for years and made numerous repairs on that car up until the transmission went. I'll take a look at your recommendations tomorrow.
Old 06-12-2016, 01:25 PM   #5
cdog999
Popped off the Air Filter and wow was there a bunch of leaves and junk in there. Sucked it all out with my shopvac and cleaned the air filter (doesn't appear too bad). Will give it a try for a bit before I tackle cleaning the throttle body. Used to love following the Richpin videos for my SL2. Trying to figure out the best way to learn about my 2005 Ion 2 right now.
I also popped off the Ecotec plastic cover. I heard that just traps in heat and doesn't really have any functional purpose.
Old 06-12-2016, 03:28 PM   #6
cdog999
EDIT: I took some pictures of the throttle body. Looks good, but then again its the first one I've ever looked at. Any thoughts? Pics are attached here.
Old 07-09-2016, 01:19 PM   #7
cdog999
Update: I thought this issue had gone away after I cleaned out the air filter and it looks like the throttle is clean. But, now the P1516 has come back along with a new code P0496 (Evaporative Emission System High Purge Flow).
Also, the last 2 times I've added gas to my Ion I've had issues with restarting the car. First time I thought it was the battery, but I got it started on try #10 after about 5 minutes. Yesterday when adding gas (after low fuel light came on) the car didn't start the first try. Second try had no issues with starting the car up.
Old 07-09-2016, 07:40 PM   #8
bern
2004 ION-2 Sedan
Replace the purge valve . It 's located on the back of the cylinder head. easy to replace 2 plastic hoses and 1 wire connector.
Add to bern's Reputation
Error P1516 ChargerIon Ion Tech 5 02-14-2017 06:48 PM
P1516 - 2000 LS2 (v6 auto) Natryn L-Series Tech 4 03-04-2014 12:50 PM
2007Saturn code P1516 grnmax7 Outlook General 0 03-13-2013 09:28 PM
Codes P0121, P2101, P1516 davesaturn Ion Tech 26 05-10-2010 05:56 PM
P1516/p2101 atlas4711 Ion General 1 12-08-2008 10:48 PM
