Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 06-07-2016, 11:51 AM   #1
KuznVue
KuznVue is on a distinguished road
2007 VUE Green Line
Default Vue/Hybrid A/C problem
I have an issue with my A/C that popped up one early summer after having repairs done from hitting a raccoon the previous Fall. Condenser coil and lines replaced by dealer. The problem appeared to late to be covered by warranty from the collision. The A/C compressor starts and runs fine but the radiator fan takes forever to kick into high to cool the condenser. Then on high speed fan the charge is shown to be fine and it spits ice cubes out of the vents. But until the radiator fan kicks into high speed the A/C does not cool properly. My question is where is the switch or thermostatic switch that controls the radiator fan to kick it into high speed????
Getting tired of waiting for the engine to warm up enough to do the chore of kicking the fan into high speed on those hot days......
Add to KuznVue's Reputation
Rate the quality of this post and help KuznVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KuznVue is offline   Reply With Quote
Old 06-07-2016, 01:21 PM   #2
Default Re: Vue/Hybrid A/C problem
If I'm not mistaken, a/c systems requires immediate cooling fan operation since the condenser coil and radiator are hot. With only high speed fan cooling being noticed well after a/c and radiator heat up, the low speed cooling fan resistor may be burned out. Cars use 1, 2, or 3 speed cooling fans with one or two fans. If yours is a single cooling fan, the low speed resistor is used for a/c cooling of the condenser coil. As the cooling system heats up along with normal a/c use in local stop and go traffic in hot weather, the cooling system will determine when to switch to high speed cooling fan use to bring high operating temps down. The resistor is a large ceramic type (check rockauto or GM parts online) located on a shelf on the driver's side front wheel well. The front portion of the splash shield will have to be removed or bent out of the way to see it. A search in Vue forums will show pictures. If you're lucky and your descriptions are correct, the resistor will be the lowest cost repair compared to a problem with the a/c system.
Old 06-08-2016, 01:41 AM   #3
KuznVue
2007 VUE Green Line
Yes I have a single fan and it runs on low speed but on a hot day the A/C will not cool until the engine warms enough to call for high speed and then the ice cold air comes out of the vents again........
I'll check for the resistor first day I get off, Thanks!!
Green Line Vue Hybrid Uses Less Fuel with Engine/Hybrid Combo Charlie Vue Green Line 8 05-29-2008 11:21 AM
Hybrid Saturn?? I don't need no stinking hybrid philip1 L-Series General 21 02-24-2008 11:41 AM
07 Vue Hybrid! bue05 Vue Green Line 15 03-25-2006 01:03 PM
Hybrid Vue? SaturnBaby2 General Saturn Discussion 14 04-14-2004 12:17 PM
Is your ION a hybrid? SonataInFSharp Ion General 9 04-28-2003 03:41 PM
