Old 06-05-2016, 04:03 PM   #1
SaturnTrooper
SaturnTrooper is on a distinguished road
Mad Emergency help!!!! Trans problems
Hey y'all! So I tested my trans solenoids and discovered I needed 2 new ones. I replaced the 2 bad ones and put everything back together to spec. I got it and started the car and there were no leaks and fluid is not low. But when its in park it's in park. Reverse is reverse. Neutral is neutral. Drive 1st and 2nd are also all reverse. Did I mess up the shift linkage somehow? Is there a diagram on what the linkage needs to look like?
Add to SaturnTrooper's Reputation
Rate the quality of this post and help SaturnTrooper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTrooper is offline   Reply With Quote
Old 06-05-2016, 06:13 PM   #2
Chazberry
Chazberry's Avatar
Default Re: Emergency help!!!! Trans problems
Did you actually pull the VB out to replace those Solenoids? Are you just referring to the linkage that connects to the Manual Valve?
https://www.youtube.com/watch?v=cwV4TPL3TDg
Add to Chazberry's Reputation
Chazberry is online now   Reply With Quote
Old 06-05-2016, 07:35 PM   #3
SaturnTrooper
[QUOTE=Chazberry;2198595]Did you actually pull the VB out to replace those Solenoids? Are you just referring to the linkage that connects to the Manual Valve?
I pulled the VB, opened the VB, took the buss plate off, then Replaced the 2 solenoids and put it all back together
Old 06-05-2016, 07:41 PM   #4
billr
How far did you "open" the VB, far enough that the check-balls may have fell out? How about the linkage that moves the manual spool, has that been checked to see if it is in place, and moves the spool?
Add to billr's Reputation
Old 06-06-2016, 10:11 AM   #5
SaturnTrooper
I'm stupid....I forgot to hook shift linkage back up after it fell down into the tranny. All is well now.....minus the fact I snapped to bolt heads off in the cover and 2 on the valve body!!! Not sure what to do about that other than get a 12 pack and a extractor set and be very careful. Luckily as of now there are surprisingly no leaks so I'll drive as it as is at the moment
Old 06-07-2016, 07:45 PM   #6
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
I've never had any luck with easy outs. Lefthand thread drill bits do wonders. Often the heat from drilling releases the broken piece and it comes right out on your bit. Harbor freight has them .
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
trans problems maybe? machflt 2008 Vue 1 10-30-2015 09:20 AM
No Voltage to IACV + Trans problems...Replace Computer or Trans Val Body or Both ialonso S-Series Tech 1 05-22-2009 03:23 PM
99 SL2 Trans. problems malbojah S-Series Tech 0 06-01-2005 06:17 AM
99 SL2 Trans. problems malbojah S-Series General 2 05-31-2005 11:54 PM
trans problems on 04 ion! dncsion Ion General 26 05-27-2004 11:51 AM
