Old 05-21-2016, 03:46 PM   #1
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
Default what is the small hole above exhaust ports?
1999 sl2 dohc, roller head
On the cylinder head there are the 4 exhaust ports and in the middle above each is a small hole. What is that for and what does it do and where does it go?
It is plugged when the exhaust manifold gasket is is in place and doesn't vent through the gaskets....
1999 sl2 dohc roller head 210k miles
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 05-21-2016, 04:47 PM   #2
Default Re: what is the small hole above exhaust ports?
Air pump emissions crap that special '99-'00's got and all '01-'02's got.
Cleaning the exhaust ports Jeeprz! S-Series Tech 5 08-18-2014 07:16 AM
Gasket Sealant for small hole in intake manifold gasket? dandy505 S-Series Tech 7 01-05-2013 12:00 PM
small tiny hole in muffler prioris S-Series Tech 9 05-19-2011 06:39 PM
Cleaning EGR and exhaust ports Joe S S-Series Tech 1 11-14-2010 11:12 PM
small hole in muffler below tailpipe? robblaw Miscellaneous Tech 4 07-20-2003 12:13 PM
