Old 05-15-2016, 08:26 AM   #1
birchmj
birchmj is on a distinguished road
Wrench Repeated replacement of TAAT Solenoid
I have a 2002 SL1 with a TAAT Automatic Transmission. I have had to replace a solenoid in the transmission now going on my third time. It will work for about one month and then burn out again. When it burns out (verified using an ohm tester), the car will no longer take off in first gear (starting in 2nd or 3rd). When I change the bad solenoid, it is all good for about another month.
I assume that I should be looking elsewhere for the true cause. Any ideas? What should I test or replace. I really appreciate any suggestions!
FYI...I have put on a need wiring connector to the transmission as the original was burnt. I have had to change the 10 amp fuse at the same time as the wiring connector because the fuse was also burnt. Both are good now.
Thanks
Add to birchmj's Reputation
Rate the quality of this post and help birchmj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
birchmj is offline   Reply With Quote
Old 05-15-2016, 08:31 AM   #2
Default Re: Repeated replacement of TAAT Solenoid
Connector tightness in the buss plate for the solenoid that contentiously fails. Finding a good buss plate is the best approach.
Old 05-15-2016, 08:42 AM   #3
Chazberry
Chazberry's Avatar
And where are you getting your Solenoids from?
Add to Chazberry's Reputation
Old 05-15-2016, 09:19 AM   #4
birchmj
@Chazberry: I bought the solenoids on ebay from usa.industries
If you have a suggested trusted supplier, I don't mind payer a higher price for the quality.
@OldNut: Thanks for the suggestion on the bus plate. Will a loose connection to the bus plate make the solenoid go bad? When I take out the solenoid, it indeed test bad out of the 4.5-6.0 ohm range without the bus plate connected. I can buy a new bus plate to make sure that isn't the problem.
Old 05-15-2016, 10:47 AM   #5
Chazberry
Chazberry's Avatar
I'm pretty sure any units you get on ebay are gonna be "used". I recently replaced my LP Solenoid with a "new" one I got from Amazon for about $50.
Are your "bad" Solenoids reading low resistance? That's an indication some windings have shorted. I don't see how any poor connections at the Harness Connector or the Bus Plate would cause that - unless you see some obvious over-heating at the Solenoid posts.
Old 05-15-2016, 11:09 AM   #6
Chazberry
Chazberry's Avatar
PS - I also did some contact pressure checking. See this fwiw . . .
http://www.saturnfans.com/forums/sho...7&postcount=10
Old 05-15-2016, 01:36 PM   #7
Buss plate connections are well oiled. Funny things happen when you energize and deenergize a roll of wire through a less that 100% connection. The one you are interested in is the inductive effect of having that suddenly deenegized solenoid terminal voltage climb up to several thousand volts. This shorts turns as you asked about.
Old 05-15-2016, 04:18 PM   #8
Chazberry
Chazberry's Avatar
Ah - those deadly inductive spikes!
Old 05-15-2016, 07:34 PM   #9
The not funny thing is those large wire wound resistive heating elements will produce enough of an inductive spike to fry the contacts in a temperature switch. engineering department was baffled. If I was failing solenoids I would be going after the buss plate if the top connector was not fried.
WTB -- TAAT Trans solenoid(s) bachands Classifieds 2 05-09-2015 11:22 PM
TAAT solenoid Q marko16 S-Series Tech 3 05-02-2015 07:53 PM
Resetting Adaptive Parameters After Taat Pressure Solenoid Replacement jcumens S-Series Tech 8 03-13-2014 09:29 PM
TAAT Solenoid Lock up flaniganjasonl S-Series Tech 7 06-25-2013 07:46 PM
TAAT Solenoid Help BRIAN41920 S-Series Tech 1 09-22-2010 01:11 AM
