Old 04-20-2016, 02:25 PM   #1
SatOut
SatOut is on a distinguished road
Default Steering handling issue
I have an Outlook question that may be more of a standard auto repair question, but figured Iíd start here.
I own a 2009 Outlook which I just bought, Iíve owned an 08 for years. Both front wheel drive.
Iíve found on the 09 that every bump in the road pulls the wheel, so much that in snow I couldnít even drive straight. I do not get this with the 08. I had it looked at and they said a sway bar linkage was loose (not broken) and that the tires were bad (actually about half way to the wear indicator). I did have them put the better rear tires up front and it helped a little.
Problem is even with the better tires every man hole cover or cracked pavement still grabs the wheel. Iíve not felt this in any other car. I canít imagine itís all from one loose linkage?
Any thoughts?
Add to SatOut's Reputation
Rate the quality of this post and help SatOut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SatOut is offline   Reply With Quote
Old 04-20-2016, 08:17 PM   #2
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
Default Re: Steering handling issue
Maybe your steering gear (rack and pinion)? I replaced mine roughly a year ago, but can't remember what steering problem I had. Not sure how much help this is for you.
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
Old 08-18-2016, 01:20 AM   #3
astraowners
astraowners is on a distinguished road
Thumbs Up Re: Steering handling issue
The assisted steering (power steering) has proverbially blown
Add to astraowners's Reputation
Rate the quality of this post and help astraowners reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
astraowners is offline   Reply With Quote
Steering/handling issues... TrotFox S-Series Tech 9 04-11-2014 03:56 PM
steering issue greenman Aura General 13 01-23-2011 07:57 PM
3.0L Oil Cooler issue NOT fixed & steering issue Partymmudasti L-Series Tech 5 08-08-2008 08:48 AM
steering wheel issue??suspension issue?? i'm dumbfounded VTVUE Vue General 8 06-17-2008 06:54 AM
Steering issue dtl S-Series Tech 3 05-10-2008 02:35 PM
