Old 04-14-2016, 10:21 AM   #1
JohnS26
JohnS26 is on a distinguished road
Default fuel line retainer
Need to replace the steel fuel lines on my 2004 Saturn ion but have no idea how to remove the retainer holding the lines to the car (without damaging it). pic for reference.
Add to JohnS26's Reputation
Rate the quality of this post and help JohnS26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JohnS26 is offline   Reply With Quote
Old 04-14-2016, 10:25 AM   #2
billysvue
Default Re: fuel line retainer
YOu didn't notice the rusty ?fastener? in the center? Clean it up and take a pic or go for the gusto
YOu'll need to do more than just replace the lines... That's some purty rust
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 04-14-2016, 11:18 AM   #3
JohnS26
I know there's a lot of rust but replacing the lines gets me back on the road for now.
Old 04-14-2016, 12:19 PM   #4
Spray some WD40 on the plastic. I think it's a plastic hanger with one bolt in the middle holding the whole thing up to the chassis. The remains of the bolt appears to be severely rusted, corroded and any attempt to remove the bolt may break it off as well as breaking the plastic hanger. The hanger may be 'U' shaped to hold each line in place. When the center mounted bolt is removed, the plastic hanger should be easily unclipped from the lines. With severe corrosion, the bolt may have expanded where the plastic holes may not allow pulling it off. If you have to replace lines, either find a replacement hanger if this one breaks off and drill a new hole to mount it or try removing what's left of the corroded bolt to reuse the mounting hole. The bolt may be made of galvanized steel, exposed too long to salting and moisture.
Old 04-14-2016, 04:11 PM   #5
JohnS26
Thank you very much. Exact info I was looking for!
Old 11-04-2017, 10:34 PM   #6
thomecar
thomecar is on a distinguished road
2000 SL
2004 ION Red Line
The bolt head rusted away leaving threaded bolt protruding from plastic fitting in picture. I elected to use sawsall and cut portion of plastic clip securing fuel lines but leaving other half of plastic clip securing brake lines held in place with rusted bolt. I purchased quantity 6 of $0.69, 3/8" ring clips covered in cushioned rubber from hardware store and used these and self-tapping 10-24 screws to secure fuel lines to underside of car. This was easier than messing with the clips held in by rusted bolts. I got fuel line kit from Rock Auto and saved $100 versus local autoparts store fuel line replacement kit. The kit worked well and was not hard to install.
Add to thomecar's Reputation
Rate the quality of this post and help thomecar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thomecar is offline   Reply With Quote
Fuel Line Supplier?-pressurized line is leaking Reliabilityman S-Series Tech 1 05-06-2015 11:31 AM
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 05:42 PM
Fuel injector C clip retainer sjackson S-Series Tech 3 11-21-2008 07:04 PM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 09:43 PM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 08:42 PM
