Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 04-07-2016, 12:20 PM   #1
Barmel99
Barmel99 is on a distinguished road
Default Air Conditioning
I have a 1992 SL2 and want to add air conditioning. I'd appreciate information on how easy or hard it is to do and if anyone has done this and a guide to doing it.
thanks
Add to Barmel99's Reputation
Rate the quality of this post and help Barmel99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Barmel99 is offline   Reply With Quote
Old 04-07-2016, 12:59 PM   #2
Default Re: Air Conditioning
The only difficulty in adding a/c to your car (or any car that never had a/c) is adding the evaporator core and thermal expansion valve to the hvac box (inside the car). Most cars and suvs in the last 20/25 years have a/c as a standard feature when it was a luxury option years ago. All other external parts in the engine bay are relatively easy for installation (should a repair be needed). Adding a/c to a vehicle never having it requires removing many parts inside the car to remove the hvac box after disconnecting heater plumbing. Most service manuals have extensive procedures when a heater core or evaporator coil are replaced where procedures explain and drawings show the extent of interior disassembly needed to have access to the hvac box. The hvac box must be disassembled on a bench to add the a/c evaporator coil assembly and the thermal expansion valve, reassemble the box and carefully realign all four pipes thru the firewall for reconnecting to heater hoses and a/c lines. Other models like L200/L300's allow easier heater or evaporator coil removal from redesigned hvac boxes without tearing apart the interior.
Search for richpin videos. He shows pictures of the hvac box out of a car and may have procedures for removing it when repairs are needed to mode and temperature doors.
Old 12-08-2016, 03:01 AM   #3
Diego
Diego is on a distinguished road
It is exactly right that to add a new air conditioning is pretty difficult if the original car doesn't comes with it, but there will be a lot of fun if we add it successfully. Thanks for sharing.
Add to Diego's Reputation
Rate the quality of this post and help Diego reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diego is offline   Reply With Quote
Old 12-17-2016, 11:35 AM   #4
Packard
Packard is on a distinguished road
1995
Get a schematic on the a/c circuit and Id look for a parts car cheaper than a junkyard . Find another sc with one it . And you gonna need the wire harness from the other sc .
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Vue Air Conditioning chuck mcmullen Vue Tech 3 06-09-2008 02:44 PM
Air conditioning dye still there? JerryHughes S-Series General 0 03-08-2008 08:52 PM
Air Conditioning sask_boi S-Series Mods 1 08-26-2006 12:31 AM
Air Conditioning DragosteaDinTei S-Series General 2 07-12-2006 02:15 PM
Air Conditioning FYI Mike94SL2 S-Series Tech 9 06-25-2006 07:06 PM
