Old 03-29-2016, 10:56 AM   #1
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
Default abnormal tire wear at inner shoulders
so, i checked the alignment. it's withing the range, but barely.
camber: front -1.6/-1.7 (should be -1+/-0.75); rear -1.7/-2.0 (should be -1.4+/-0.75)
toe: front 0.28 (should be under 0.30 IIRC); rear 0.21 (should be under 0.35 IIRC)
all in degrees.
would you realign with those values?
the camber is not adjustable, but aftermarkets bolts and shims are available at $8-10 a piece and it's not that hard according to the instructions.
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
Add to jacek_p's Reputation
Rate the quality of this post and help jacek_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacek_p is offline   Reply With Quote
Old 03-29-2016, 11:35 AM   #2
billysvue
Default Re: abnormal tire wear at inner shoulders
With "abnormal tire wear at inner shoulders" , yes ,recheck, realign, do what you have to do.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 03-29-2016, 07:06 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
GM has revised the Ion's wheel alignment specifications on the Ion at least twice (TSBs 05-03-07-007 - dated 6/7/2005 and 05-03-07-001B - dated 7/27/2005). I have attached a copy which has the revised specifications to ensure you are referencing the correct data.
Saturn_Ion_wheel-alignment-specifications.pdf
2007 Ion 2 Quad Coupe 5-speed manual 183K miles
2007 Chevy Equinox LT 195K miles
2018 Chrysler Pacifica Touring L 48K miles
Add to ruley73's Reputation
Old 03-29-2016, 10:34 PM   #4
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
Attachment 45789
thanks. not sure what jounce bumper i have, but suddenly the normal alignment turned into abnormal one. I guess i'll be getting the shims when i figure out the jounce bumper situation.
Old 03-30-2016, 03:50 PM   #5
2006 ion2
2007 ION-2 Sedan
I would realign the camber and toe.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 03-30-2016, 10:17 PM   #6
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
this is what i'll do. i'll add +1 degree camber to each wheel and that will put me in range for both jounce bumper types. why would that matter anyhow?
will reevaluate toe later, but it looks good now.
Old 03-31-2016, 07:18 PM   #7
ruley73
ruley73's Avatar
Your car most likely has the one-piece jounce. They revised the rear axle during the 2006 model year. One of the TSBs I referenced summarizes the changes. It basically says to use the old parts until they are exhausted. Once all the old parts are used up then the entire rear axle needs to be replaced with the newer style if it ever needs to be serviced. The newer style has the two-piece jounce.
Old 04-13-2019, 09:28 PM   #8
Ecomike
Ecomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of lightEcomike is a glorious beacon of light
Attachment 45789
I have two Saturns, but I am Jeep....etc person experience wise.
What is the 1-2-3 of the FE1 FE2 FE3 on that spec sheet, and what in the world is a Jounce bumper? Trying to pick up some Saturn ION ( 3-?) info before I started my own horror show thread on our new to us 2003 Ion
Add to Ecomike's Reputation
Rate the quality of this post and help Ecomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ecomike is offline   Reply With Quote
Old 04-14-2019, 03:05 PM   #9
ruley73
ruley73's Avatar
The jounce bumper is mounted on the top side of the coil spring to circumvent bottoming out.
The FE1/FE2/FE3 is the suspension code as shown on the RPO code sticker on the left side of the floor in the trunk. Only Red Lines came with FE3. Some Ion-3 models came with FE2. All others have FE1 suspension.
The springs/shocks/struts are FE1 (soft) >>> FE2 (firmer) >>> FE3 (firmest).
Old 04-14-2019, 04:06 PM   #10
Ecomike
Ah, now I get it. Thanks, I rarely need to mess those, and slept since I last saw one, LOL. Always just called them a bump stop I guess (Jeep lingo).
Anyone replace brake pads - abnormal wear Tom S2 Astra General 35 11-02-2013 10:11 PM
Is this brake wear abnormal? kevo420 S-Series Tech 4 07-26-2008 10:42 PM
Tire Wear LS2 Bgrutza L-Series General 2 10-16-2005 11:00 PM
What can I do about this tire wear? erik85 S-Series Tech 3 11-15-2002 12:34 AM
Crank Wear - Abnormal ? sw2worn S-Series Tech 1 07-05-2000 07:48 PM
