Old 03-21-2016, 03:08 PM   #1
jbm367
jbm367 is on a distinguished road
Default 2000 Saturn LS1 2.2 liter
I have a 2000 model Saturn 2.2 liter that I recently acquired from my father in law, I had to put a new wiring harness on it because he put a new motor in it a few years back. My issue is a crank and no start. Every time I turn the key from off to the on position I blow a 10amp fuse (controls ign 1) is what its labeled. I have checked the wiring harness and don't see any visible short or grounds not in place. I'm thinking a short in the starter solenoid but not sure. There is another issue of when that fuse does blow all the lights in the dash start blinking very fast and very dim. Any insight would be greatly appreciated. When the engine is turned over everything sounds fine except for actually starting.
Add to jbm367's Reputation
Rate the quality of this post and help jbm367 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jbm367 is offline   Reply With Quote
Old 03-21-2016, 04:52 PM   #2
pierrot
pierrot's Avatar
Default Re: 2000 Saturn LS1 2.2 liter
Welcome to SaturnFans! Your vehicle underwent some major work. Are you confident that all of the ground locations, including the multiple wire grounds - if any - are connected cleanly under the hood?
278,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 03-21-2016, 08:33 PM   #3
Originally Posted by jbm367 View Post
I have a 2000 model Saturn 2.2 liter that I recently acquired...... I had to put a new wiring harness on it because he put a new motor in it a few years back. My issue is a crank and no start. Every time I turn the key from off to the on position I blow a 10amp fuse (controls ign 1) is what its labeled......
When the new motor went in, is it new, rebuilt or a different motor altogether? When it was installed, was the original wiring intact, allowing the engine to run? And why is a new wiring harness needed? Is there a possibility of this new wire chafing somewhere and causing the fuse to blow? Replacing a major wire harness suggests greater awareness needed when snaking wires around with caution against catching a sharp edge, damaging a wire and/or causing electrical problems.
Old 03-21-2016, 10:04 PM   #4
jbm367
I have two multi grounds and one is connected with another single wire, the other is connected with 3 other single wires. I just replaced my starter hoping for a change with no avail.
Old 03-21-2016, 10:06 PM   #5
jbm367
The motor was not new. I had to rob another harness from an intact car because the harness that was about to be installed had the wrong plug going to the dash harness. There is a possibility of the newer wiring being chafed I am checking now and hoping to find the culprit.
Old 03-22-2016, 08:06 PM   #6
jbm367
does anyone have a 2.2 l series car that can send me photos of all the grounding wires and locations? I found that if I hook two of the grounding wires up it blows the fuse but if they are off it doesn't. Does this mean I have a short in the harness or have my grounds in the wrong place?
Old 03-22-2016, 08:59 PM   #7
I don't know if these wiring diagrams helps but if members cannot help, you might consider subscribing to alldata or Mitchell for online service manual info. There may be more here than anyone can imagine as there are many paths to blow a fuse that doesn't require connecting grounds (as the two drawings show). There may be a short in one of the circuits or component to consider that might require careful troubleshooting beyond the scope of anyone here attempting to diagnose this problem sight unseen.
2000 Saturn L2,3.0 liter engine shows P0121 code rlphillips9002 L-Series Tech 6 07-13-2013 11:46 AM
Intake For 2000 Saturn LS2 3.0 liter V6 TacusiLS2 L-Series Tech 4 02-27-2013 10:37 PM
3.6 liter Saturn Don Pitts Outlook General 1 11-18-2011 12:44 AM
saturn 1.9 liter presnell48 L-Series Tech 4 09-14-2011 03:51 PM
98 saturn 1.9 liter sl2 presnell48 S-Series Tech 2 09-13-2011 07:39 PM
