Old 03-05-2016, 05:54 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Dizzy P0300 P0446 and P0410
Three codes all of sudden in 2001 Saturn sl2
Can it be only one reason why all 3 codes above appeared together?
check engine lite is on
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 03-07-2016, 08:09 AM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: P0300 P0446 and P0410
I don't see a single event that would cause these 3 codes. P0300 is random multiple misfires. Can be ignition or fuel related. P0410 is the famous secondary air injection system failure. Richpin has a good video to help diagnose this one. These two could be related if there is a small vacuum leak in the secondary air system, as that can cause a misfire at idle and render the secondary air system inoperative.
P0446 is not one I'm very familiar with, but is evaporative system related. From what I've read, this has to do with improper voltage at the purge solenoid.
BV22
2002 SC1 5M
301k 12/17
Add to BV22's Reputation
Old 03-10-2016, 06:36 PM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Ok only P0446 is left ...other two codes are gone..thanks..
Old 03-14-2016, 07:15 AM   #4
BV22
2002 SC1
Did you fix something, or did they just go away?
Again, I don't know much about P0446. I would probably clean the electrical connection at the purge solenoid as a first step.
BV22
2002 SC1 5M
301k 12/17
Old 03-14-2016, 09:37 AM   #5
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Replaced secondary air injection related components.
I thought p0446 is outcome of vent solenoid circuit and not purge solenoid
Old 03-14-2016, 10:10 AM   #6
BV22
2002 SC1
You are correct - vent circuit, not purge circuit. Sorry.
BV22
2002 SC1 5M
301k 12/17
P0446 dtc dws41951 Vue Tech 8 06-22-2015 10:32 AM
p0446 3saturns Ion Tech 15 03-15-2015 12:10 PM
2002 sl2 p0300 p0410 spurs2010 S-Series Tech 5 06-06-2014 09:16 PM
P0446 bob3434dog Vue General 4 04-07-2010 06:26 PM
p0446 maximuscrates S-Series Tech 4 08-13-2009 10:05 AM
