Old 03-04-2016, 06:04 PM   #1
robb_sc2
robb_sc2 is on a distinguished road
Default Valvoline long life coolant
Did a coolant flush at the local iffy lube, after doing the water pump. Not sure why, they are the ones that broke my oil drain plug nut off inside the pan... Anyway, they used Valvoline longlife coolant. Didn't have a chance to ask if it is phosphate free ethylene glycol. The Valvoline website claims universal compatible, but they do list a dexcool specific replacement so now I'm nervous. Please calm my fears or confirm them!
Gold 1999 SC2 ~385k Kms
Add to robb_sc2's Reputation
Rate the quality of this post and help robb_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robb_sc2 is offline   Reply With Quote
Old 03-04-2016, 07:22 PM   #2
Default Re: Valvoline long life coolant
From the service manual; The Saturn cooling system is filled with DEX-COOL™, a non phosphate, silicate free ethylene glycol-based antifreeze recommended for aluminum engine protection and increased water pump seal life.
With all the discussions for and against coolant formulations and the harm caused from possible misuse of incorrect coolant, its more or less hearsay distracting the main reason major coolant manufacturers revise their formulas - to ensure their coolant is compatible with engines and materials to prevent chemical reactions, galvanic corrosion or conditions that would lead to cooling system damage. Since cast iron engines led to cast aluminum engines or aluminum cylinder heads and use of aluminum for heater cores, coolant formulas required changes to accommodate dissimilar metals from reacting with each other thru liquid coolant.
If you are sure Valvoline is used, visit Valvoline's site and read their coolant formula. They should be able to give you info about their compatibility to cooling systems.
Old 03-04-2016, 09:11 PM   #3
The latest formulations are phosphate free and ethylene glycol based. The Valvoline product is all makes all models compatible. It should be perfectly fine.
Old 03-07-2016, 02:39 PM   #4
hholbein
1997 SW2
+1. Probably no worries for 5 years. For the past 10 years I've run Valvoline's Zerex G05 yellow coolant and it's been a champ @ 60%+ concentration. Much less scuzz in the expansion tank than I experienced with the original Orange Julius Dexcool stuff.
Still on my original radiator, water pump, hoses. Knock on plastic.
Add to hholbein's Reputation
How likely is a VUE 3.0 V6 to live a long life travlincub321 Vue General 6 03-02-2013 04:16 PM
Forums for 'long life maint'/less $ brokendown General Saturn Discussion 0 08-15-2012 01:05 AM
valvoline Max Life Trans Fluid highdollar Vue Tech 3 12-30-2008 11:29 AM
Peak Long Life Antifreeze 1stSaturnowner L-Series Tech 8 04-17-2006 08:29 AM
Valvoline Max Life Oil njacinto Miscellaneous Tech 0 02-24-2002 11:48 AM
