Old 02-29-2016, 11:01 PM   #1
Saturn_ol'timer
Saturn_ol'timer is on a distinguished road
2002 SL1
2002 SL
Default Need to siphon gas from 2002 Saturn SL. Does this clamp hold two lines together?
Hello,
I have a 2002 Saturn SL that has set up for 18 months. I thought it would be best just to siphon the old fuel out. I didn't want to subject the fuel filter or fuel pump to any unnecessary hardship. After removing the driver's side rear tire, one of the two fuel lines that descend from the fuel door area to the tank is visible in the picture. It is the smaller line that I believe does not contain a check ball. I tried to separate the line at the clamp shown in the picture, but it did not pull apart. My plan was to siphon through this hose, but I am not sure if it is a molded line with differing diameters, and the clamp is for reinforcement, or if it is two separate lines of differing diameters held together with the clamp. I don't have access to a parts diagram. Does anyone know?
Thank you
Add to Saturn_ol'timer's Reputation
Rate the quality of this post and help Saturn_ol'timer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn_ol'timer is offline   Reply With Quote
Old 02-29-2016, 11:37 PM   #2
Default Re: Need to siphon gas from 2002 Saturn SL. Does this clamp hold two lines together?
There is a siphon trap further down that pipe and you will have a real mess. Use the fuel pump and pump it out.
Old 03-01-2016, 12:48 AM   #3
The service manual suggests one of three ways to drain fuel; pumping it out from the fuel fill opening, disconnecting the fuel fill pipe and siphoning from the tank, using the fuel pump to pump fuel out thru the test valve on the fuel rail or from disconnecting the the fuel inlet line to the fuel filter under the car. Precautions are mentioned to use an appropriately sized tube if pumping fuel out the fuel fill opening and may be problematic if an incorrect tube is used and becomes lodged in the check valve (italicized note below). The easiest and maybe the safest way might be disconnecting the fuel line to the fuel filter, placing the hose into a gas container and powering up the fuel pump by removing the fuel pump relay and inserting a short wire jumper across relay terminals 30 and 87 - this sends 12v to immediately power up the fuel pump (regardless of ignition switch position). Since the pump runs all the time the engine runs, running the pump manually is no different (with a wire jumper in the pump relay socket terminals) won't cause pump harm. Pressures are high so someone may be needed to ensure the fuel line doesn't come out of the gas container when the pump is powered up.
Service manuals never mention the possibilities of aged parts that may break after years of use so disconnecting anything can have unintentional consequences.
Keep fuel filler pipe as straight and level as possible when removing it from the tank. Fuel fill check valve clamp may drag on the inlet neck of the tank and care should be used in removing it. If valve is dislodged from filler pipe it may remain in the tank.
Old 03-01-2016, 01:20 PM   #4
Saturn_ol'timer
2002 SL1
2002 SL
Thank you guys for your insights. fdryer, the pics were helpful.
2002 v6 transmission lines wyoguy Vue Tech 1 05-20-2015 02:52 PM
Siphon gas from my 99 sl1 83trekker S-Series General 10 10-27-2012 02:33 PM
cloged drain lines on a 2002 vue rustydrip Vue Red Line 1 11-03-2011 10:19 AM
2002 Saturn L300 ECM Wiring "Clamp" or "Fastner" busboy99 L-Series Tech 1 09-06-2011 06:18 PM
how not to siphon gas from your Saturn alordofchaos S-Series General 7 07-23-2011 10:55 AM
