Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 02-24-2016, 06:06 PM   #1
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Question Aftermarket transmission oil pan - with drain hole/bolt
What do you all think of Dorman transmission oil pan 265-809 with a drain hole and drain bolt which should make changing the transmission fluid (and filter) easier...?
It should fit some of the 2007-2009 Auras, 2005-2007 IONs, 2001-2005 L-Series , 2004 L300s , 2006-2010 VUEs, as well as some other GMs that have the same GM 4T45-E automatic transmission.
www.amazon.com/gp/product/B002XIKJO4
http://www.rockauto.com/en/moreinfo....533948&jsn=232
As of Feb 2018
∙ 2004 VUE 122K
∙ 2007 ION3 110K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 10-30-2016, 09:19 PM   #2
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: Aftermarket transmission oil pan - with drain hole/bolt
My 2007 ION-3 with the automatic transmission is almost at 100,000 miles. Today I changed the transmission fluid (Mobil-1 synthetic Dexron VI ATF), replaced the transmission pan (Dorman 265-809 with drain bolt), and replaced the gasket plus filter plus ring seal thing (ATP B-171).
Everything worked out great. The only hard part of the job was removing the ring seal thing on the bottom of the transmission where the filter connects. Now I look forward to changing the transmission fluid more often while leaving the pan, gasket, and 12 bolts alone.
I followed the instructions found in the following excellent video: https://www.youtube.com/watch?v=14jSdg6c-Xs
I did two things differently.
  • My driveway slopes slightly downhill from the garage. I backed into the driveway and put the front end of the car on jack stands high enough to let me comfortably get underneath the car. The car was not yet level. Then I loosened some of the bolts on the pan to allow the old fluid to drain from the front end (the pan is shaped like an "L" and the fluid drained from the top of the narrow "L" into my basin without making much of a mess. After that I raised the car higher to make it level for correctly adding/overflowing the new transmission fluid.
  • Instead of using a funnel and a few sections of hose, I used one of these things which are perfect for adding transmission fluid: https://www.amazon.com/Hopkins-10106...dp/B000EH4UXM/
As of Feb 2018
∙ 2004 VUE 122K
∙ 2007 ION3 110K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 05-06-2017, 08:48 AM   #3
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Aftermarket transmission oil pan - with drain hole/bolt
Have used this Dorman pan on 2 of my L-Series wagons. Quality item!
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
new silla rad leaking at the drain hole Jeeprz! S-Series Tech 6 05-16-2015 08:53 PM
Front seal oil drain hole Lilchief S-Series Tech 1 03-26-2013 04:42 AM
Evap Drain Hole SaturnIONSLVUE Ion Tech 1 05-13-2010 03:01 PM
Water drain hole in OE muffler? bryan_johnson S-Series General 3 04-15-2005 11:29 AM
Transmission Drain plug hole "buggered up" roswell998 Miscellaneous Tech 4 11-24-2004 09:17 PM
