Old 02-21-2016, 08:20 PM   #1
03l300
03l300 is on a distinguished road
Dizzy p0171 and p0174 issue
i got a 2003 saturn L300 with 110,000 on it i keep on getting these codes which is p0171: system to lean bank 1 and p0174: system too lean bank 2. does any one know what can be the problem?
i replaced a hose by the gas tank. i checked the air filter its good. i cleaned the MAF sensor. i replaces the gas cap. also a car with a wrench will come on and when its on the car will jerk.
Add to 03l300's Reputation
Rate the quality of this post and help 03l300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
03l300 is offline   Reply With Quote
Old 02-22-2016, 02:59 AM   #2
Default Re: p0171 and p0174 issue
Both error codes have something in common. If you have a reader, monitor and record all data and post them. The service manual describes possibilities;
  • A skewed mass air flow (MAF) sensor may set this DTC. Refer to DTC P0101 .
  • The system will go lean if an injector is not suppling enough fuel.
  • The system will go lean during high fuel demand.
  • An EGR valve stuck open may set this DTC.
  • A skewed engine coolant temperature (ECT) sensor may set this DTC.
  • Review the Failure Records with a scan tool. If an intermittent condition is suspected, refer to Fuel Injector Coil Test .
OBD 2- P0174, P0403, p0171 Ravadhani L-Series Tech 3 07-14-2013 02:47 AM
08 XR Code P0174 & P0171 Matt V Aura General 6 01-21-2012 09:55 PM
P0171 P0174 codes on 3.0 Vue IMkenNY Vue Tech 4 04-03-2009 05:05 AM
P0507, P0171, P0174 (3.0 V-6 L81) wfransee Vue Tech 1 12-20-2007 05:57 PM
Need advice - P0171 & P0174 Hakman L-Series Tech 8 07-05-2007 02:01 AM
