Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 02-21-2016, 04:50 PM   #1
Redline2004
Redline2004 is on a distinguished road
Default Engine Ground Wire (braided)
Hello,
New member, first post. I was doing some routine maintenance on my car and I happened to notice a major ground strap loose (see photo). It is located on the top of the engine (viewed from under the hood), on the drivers side of the engine. The engine end of the wire is securely fastened to the engine block, but the other end is floating. I cannot see anything nearby that it could even reach to. It is possible the other end was put back on in the wrong orientation so it isn't reaching what it is supposed to. If anyone can check theirs out or has an answer to this it would be greatly appreciated.
Thanks!
Add to Redline2004's Reputation
Rate the quality of this post and help Redline2004 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Redline2004 is offline   Reply With Quote
Old 02-21-2016, 05:20 PM   #2
hoosierrun
hoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nice
2006 VUE 2.2L
Default Re: Engine Ground Wire (braided)
Originally Posted by Redline2004 View Post
Hello,
Thanks!
I have a picture of that ground strap where it is attached to the head on a 2006 Saturn Vue 2.2. I had the head off and photographed different angles so I would know how it goes back. Don't know if this will help. The other end goes to the valve cover and I believe there was a stud facing the driver's side with a nut securing that strap.
John.... 2006 Saturn Vue, 2.2, 186,000 miles Recently junked out - (threw a rod)
Add to hoosierrun's Reputation
Rate the quality of this post and help hoosierrun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoosierrun is offline   Reply With Quote
Old 06-28-2018, 01:18 AM   #3
Alexferguson
Alexferguson is on a distinguished road
So I final got my new replacement pump from amazon $95 bucks, after swapping them out I took the old one apart and found that the steel bell was broken into 4 pieces, the impeller is magnetic driven, see pic, also I am thinking about doing a color change when I paint it, black now, want something that pops but not to bright, haven't decided on when to do it but I know less than 6 k where built just thinking ahead
Add to Alexferguson's Reputation
Rate the quality of this post and help Alexferguson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexferguson is offline   Reply With Quote
Braided ground strap... discostu1982 Ion Tech 3 01-07-2011 12:59 PM
ground wire upgrades petdmc S-Series General 13 04-18-2007 03:13 PM
Best place for ground wire 97SatGuy S-Series Tech 6 04-06-2007 02:39 AM
Where to Ground Wire ? tenn734 S-Series Mods 5 12-23-2005 11:22 AM
Aerospeed Ground Wire Kit? Bigbadbert Mods and Performance 34 02-21-2003 09:30 PM
