Old 02-19-2016, 10:21 AM   #1
Mikesutch
Mikesutch has a spectacular aura aboutMikesutch has a spectacular aura about
Default 2001 SL1 exhaust size request
My exhaust flanges rotted and broke off both sides right behind the O2 sensor. I'm planning to use split flanges to repair it but not 100% sure what sizes I need. I saw another post that looked the same. I'm thinking 1 3/4- 2 and 2- 2 1/4 would do it but just want to make sure before I buy anything and schedule time with my buddy's ramps.
Can someone suggest the best sizes for a 2001 SL1 and should I get something to stick between the pipes? A graphite gasket or something?
Add to Mikesutch's Reputation
Rate the quality of this post and help Mikesutch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mikesutch is offline   Reply With Quote
Old 02-19-2016, 11:25 AM   #2
trottida
trottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of light
trottida's Avatar
Default Re: 2001 SL1 exhaust size request
As an alternative you could cut the flanges off and weld a pipe in there to bridge the gap. How many times have you needed to undo that joint in the past?
Current rides
2001 SL1 MT (410,500 km @ 11/2017)
1999 SL2 MT (251,500 km @ 11/2017)
2011 Suburban LT (101,450 km @ 11/2017)
:canada:
Add to trottida's Reputation
Old 02-19-2016, 11:26 AM   #3
Mikesutch
I dont have access to a welder otherwise I'd just repair it the correct way. I've never had the exhaust apart before.
Old 02-19-2016, 05:18 PM   #4
saturnsctwo
the best way for a repair is to just let an exhaust shop weld in a straight pipe like they did on my car which to this day is tight & no leaks or rust there. cost me around $70.00. they also re-welded the sensor shield on the new pipe section. those split flanges tend to let loose & cause leaks/rattle I'm told. they strike me as just a temporary repair at best....
Old 02-19-2016, 05:27 PM   #5
ratwhisperer
ratwhisperer will become famous soon enough
ratwhisperer's Avatar
1997 SL1
I agree. On my 2000 that I used to have this same thing happened, and we tried the split flanges and it just came loose and leaked. It was more worth it to just go have the straight pipe welded on at the shop. I think I spent yeah, like $70-$80. Can't remember exactly but it was less than $100.
Past:
1995 SW2 - Cynthia - sold 246K
2000 SW2 - Ruby - sold 165k
2004 Vue - Jade - traded in
1996 SL2 - Ursula - sold 223K
Current:
1994 SL2 - Nelly Belle - 139K?
1997 SL1 - Cinnamon - 265K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 02-19-2016, 05:34 PM   #6
saturnsctwo
even if the flanges held up they are just another piece of hardware that would rust out. the easy thing is to just let them weld In the pipe. while they had the car up on the rack they welded on new hangers on the cat converter & rear pipe. the steel hangers tend to rust & thin out over time. the last thing they did is to weld in a new stainless flex pipe. their flex pipe is made from high grade stainless & so far has not deteriorated, so my exhaust is ready for many more years of service.....
Old 02-19-2016, 05:35 PM   #7
Mikesutch
Dizzy Re: 2001 SL1 exhaust size request
Alright alright. Fine I'll do it the right way..
Help/info request-08 Astra exhaust Catch 22 brigid Astra Tech 4 11-23-2015 06:01 PM
Exhaust pipe request. aperseghin S-Series Mods 5 05-15-2007 11:28 AM
exhaust size? pauleqer S-Series Tech 2 05-07-2007 09:11 PM
Exhaust helpers:OBX + SPS exhaust = What size cat? teamtruett S-Series General 0 12-15-2006 09:09 AM
Exhaust size SlamdS10 Mods and Performance 7 06-18-2005 09:20 PM
