Old 02-16-2016, 01:02 PM   #1
Dogman68
Dogman68 is on a distinguished road
Happy Am/fm radio problem
Hello out there! I need some help with my 99 Saturn sl (Radio) the am/fm was working, but now you can"t change stations their is nothing showing on the screen I can get one channel (poorly) and a lot of static I installed a different factory radio but get the same results I would appreciate any help thank you in advance RLF.:
Add to Dogman68's Reputation
Rate the quality of this post and help Dogman68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dogman68 is offline   Reply With Quote
Old 02-16-2016, 08:40 PM   #2
Default Re: Am/fm radio problem
Have you checked your antenna and its cable connections? Is this reception problem something which happened gradually or all of a sudden?
If I'm understanding you correctly, you're only able to receive one channel with the replacement radio. Regardless of reception, can you change channels or see anything on the screen with your replacement radio or not?
(Greater care with punctuation in your post would make your sentences more easily understood.)
287,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 02-16-2016, 09:22 PM   #3
Dogman68
Happy Re: Am/fm radio problem
pierrot ! thank you for the quick reply,, pardon the grammer I"am not very educated. The radio had worked good , But during my extensive search as to why their was no spark to my plugs including removing the E.C.M. and reinstalling, I now have the radio issue, it was not possible to change channels and no features on the screen.I bought the same radio on ebay and installed it, with same problem, so their is my delema, I read something about a (code) issue with Saturn sl and have no idea how to attempt repair, even if it is possible I would appreciate any ideas thank you RLF.
Old 02-16-2016, 10:40 PM   #4
So all of this began to happen with your radio after you were doing work around the ECM? Was there any wiring problem associated ECM's removal and re-installation? While you were removing and reinstalling that part were you doing so with the battery disconnected or connected?
I'm not at all familiar with the S Series radios and why they should behave unusually in this way. The L Series cars have only one radio with any kind of security built into the unit and although I now have one of them, I've not activated the security feature. In my case the upgrade from the CD-AM/FM radio which was originally in the car, to the CD-Cassette Deck-AM/FM radio was basically a "plug and play" operation with no problems whatsoever.
I would suggest copying your original message here and placing it in one of the S Series Forums where you're likely to get more helpful replies.
Old 02-17-2016, 06:16 PM   #5
ruley73
ruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to all
ruley73's Avatar
2007 ION-2 Quad Coupe
Since the issue was replicated with two known good radios, the problem is likely elsewhere. Start by checking your fuses; specifically the 10A RADIO and 10A CHIME fuses in the interior fuse panel on the right side of the console. The radio fuse only affects the radio, but the chime fuse will also kill your chime warning & keyless entry (if equipped with power locks) if it is blown.
2007 Ion 2 Quad Coupe 5-speed manual 177K miles
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Radio problem jcapartmentsale S-Series General 22 03-30-2015 08:15 AM
Radio problem biscayne Vue Tech 1 10-24-2010 07:16 PM
Radio Problem osaturn Ion Tech 3 11-04-2008 09:50 AM
RADIO problem? and door lock problem please help 95sl2urbo S-Series Tech 15 01-11-2004 08:25 PM
Radio Problem - Can't get anything theericharris S-Series Tech 2 11-29-2002 12:22 PM
