Old 02-16-2016, 12:18 AM   #1
jeffsal87
jeffsal87 is on a distinguished road
Question Engine crank but no start. No Security light
Engine cranks but no start and no security light indicating Passlock fault...?
Drilled out old lock cylinder and replaced with new one a few days ago when it locked up and we couldn't get it started. After I re-keyed and installed new cylinder, it started up for me a few times before seizing up again. I removed the whole ignition housing unit and messed around with it till I could get the new cylinder out (in one piece) and figured out the mechanics causing it to seize. Now I can get it to turn over but it will not start. No code besides P0480 and no security light comes on indicating a Passlock problem. Stuck and looking for a little insight before I buy more parts.
Add to jeffsal87's Reputation
Rate the quality of this post and help jeffsal87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeffsal87 is offline   Reply With Quote
Old 02-16-2016, 12:33 AM   #2
Default Re: Engine crank but no start. No Security light
Do you see the Passlock symbol at ignition ON time (when all instrument lights turn on) then observe it turning off? If so, this isn't a Passlock problem. This may be a crank sensor failure, fuel or spark problem.
Old 02-16-2016, 01:14 AM   #3
jeffsal87
Yes sir. That is what I have been observing. Before you posted on this I was researching all possible out comes and pretty much narrowed it down between crankshaft sensor and ignition module. But the more I'm reading about the CPM and its symptoms. The more I'm being able to relate to it. The higher running rpms, irregular fluxs in idle, engine turns over but no ignition, etc.... My biggest worry at the time is being absolute before proceeding any further.
security light/ no start tink65 S-Series Tech 6 01-26-2015 04:44 PM
NO security light & no start L200 goongreen L-Series Tech 6 08-22-2014 12:14 AM
no start / security light CoJames L-Series Tech 10 02-12-2013 04:45 AM
security light - car won't start: possible solution dandy505 S-Series Tech 3 09-15-2012 08:24 PM
Vue doesn't start, security light on oleg1969 Vue General 0 01-14-2007 10:13 AM
