Old 05-06-2016, 08:03 PM   #21
Murderotica024
Murderotica024 is on a distinguished road
Default Re: Downshifts from 4th to 3rd on its own & Reverse Slam
I think it was the changing of the spark plugs and wires. The spark plugs were pretty in terrible shape. There was a slight amount of oil in the first spark plug well so I replaced the valve cover gasket and haven't had an issue since. If the weather gets better tomorrow, I'm going to go out and try to get that 0341 code taken care of
Add to Murderotica024's Reputation
Rate the quality of this post and help Murderotica024 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Murderotica024 is offline   Reply With Quote
Old 05-07-2016, 12:11 PM   #22
Murderotica024
Originally Posted by Chazberry View Post
What was it that fixed the P0300? See if you can get that P0341 cleared . . .
I checked the ohms of my coil packs and they read 7.83 and 7.9. That thread you pointed me to said about having 8.0 minimum. Would that .17 and .1 be the issue? Also, this reading was after I pulled the cool packs out and cleaned them thoroughly with a wire brush
Old 05-07-2016, 12:18 PM   #23
Chazberry
Chazberry's Avatar
I wouldn't think so, but I don't have experience with this. Are you sure the wire routing is good?
Add to Chazberry's Reputation
Old 05-07-2016, 12:21 PM   #24
Murderotica024
If you mean correctly corresponding to 4-1-2-3 then yes. And if you are referring to the wires themselves, I hope they are good. They are new wires that I purchased a couple months ago. After putting the wires and everything in, I no longer had the 0300 error but this 0341 won't go away
Old 05-07-2016, 02:31 PM   #25
Chazberry
Chazberry's Avatar
Not so much that, but this . . .
"The #1 and #4 plug wires must run parallel and adjacent to each other from the coil to the head."
You can check the resistance of those also.
Old 05-07-2016, 04:12 PM   #26
Murderotica024
I'm not sure what you mean by they must run parallel and adjacent to one another
Old 05-07-2016, 10:20 PM   #27
Chazberry
Chazberry's Avatar
It's important how the wires are arranged in the looms - although the #1 and #4 wires don't look adjacent in this photo (?) . . .
Reverse slam and slam in all gears after replacing bad solenoids OldManTain S-Series General 4 07-14-2014 08:50 PM
Tran Slam From Reverse to Park and Reverse to Drive fmctaurus S-Series Tech 4 03-09-2012 10:00 AM
Reverse slam cure worked, still shaking very bad in reverse Bigjohn L-Series Tech 2 04-22-2011 10:07 AM
reverse slam, slam into 2nd, p0732, now no reverse...new valve body? nd99sl2 S-Series Tech 12 09-28-2010 09:07 PM
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 05:48 PM
