Old 06-23-2003, 03:34 PM   #1
jamartini99
jamartini99 is on a distinguished road
Sad help with leaking sunroof
can anyone give me some advice how how to stop my sunroof from leaking on my 98 sl2. i live in florida and gets two inches of water in the interior of my saturn every time it rains. the problem is the drains keep clogging. i have then blown out with air and its fine for a day or two and then they must clog again. if anyone has a suggestion please write back. the entire sunroof module was replaced less than year ago. i know its the drains that are a problem. thanks for any advice......
jamartini99 is offline
Old 06-23-2003, 10:34 PM   #2
9TWOSC
9TWOSC is on a distinguished road
Default
Hey fellow Floridian ,
I have issues with mine too 92SC The drain above the drivers side seems to get plugged alot Hope someone can answer your question i need help too
9TWOSC is offline
Old 06-24-2003, 03:53 PM   #3
Jay2000
Jay2000 is on a distinguished road
Default
Even if you park under a pine tree like I do, it shouldn't clog up that fast. Are you sure it is getting cleaned out throughly?
I clean mine from the bottom. In the front, there is a kick panel that can be removed to access a tube. It fits into a rubber stopper like thing that keeps critters from crawling in. This can be cleaned. Just be sure you can get it back in place.
The rear is harder. If I remember right, I had to loosen up the rear quarter panel from area near the back door. The stopper like thing is to the left (and maybe upward) from the gas tank filler on my 99 sl1.
I haven done this in a while so I hope my description is right.
Jay2000 is offline
leaking sunroof Bornrebel S-Series General 2 11-26-2007 11:27 PM
Leaking Sunroof wish4eagle S-Series General 1 02-23-2007 12:38 PM
hELP WITH SUNROOF LEAKING 1993 S-Series Tech 3 11-07-2006 05:39 PM
Sunroof Leaking cutiep S-Series Tech 5 03-31-2005 12:02 PM
Leaking Sunroof DJMaverick S-Series General 3 10-15-2004 05:28 PM
