Old 01-29-2016, 12:32 PM   #1
msaturna
msaturna is on a distinguished road
Default Bad wheel bearing.. what part do I need?
car is a 2001 saturn l200
Think the wheel bearing is going bad on my front left wheel. When I drive on smooth roads it sounds like there's a wobbling noise/like im going over a wavy surface or something similar, so i think it's the wheel bearing. i still need to do the 3/9 and 12/6 test..
anyway, do i need a separate bearing and wheel hub or do i need the assembly? are they interchangeable? i have used the parts compatibility tool on sites like oreilly/autozone with varying results. oreilly wants to sell me separate bearing + hub while autozone says i need an assembly. the only difference i can see is that the assembly is much more expensive than just buying the bearing and hub.
if i can use the assembly, do i still need a shop press for anything? i watched a chrisfix video of him replacing a bearing on a mercury mountaineer and there wasn't any press involved so i'm guessing its an assembly. any ideas?
Add to msaturna's Reputation
Rate the quality of this post and help msaturna reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
msaturna is offline   Reply With Quote
Old 01-29-2016, 01:18 PM   #2
pierrot
pierrot's Avatar
Default Re: Bad wheel bearing.. what part do I need?
Welcome to SaturnFans!
Be sure that it is a bad bearing giving you the noise and not a failing CV joint. As far as the parts are concerned, you don't necessarily have to replace the hub unless it's been damaged. Of course, you can't do any harm by replacing the hub. The is no hub assembly per se for the front axle which is similar in any sense to the rear wheel hub assemblies. The parts are sold by some suppliers as a kit of separate pieces.
Regardless of what this video showed on a Mountaineer, the L Series front wheel bearings need to be removed and installed via a press, there are no other options. (It's possible that the shop performing the press work may inform you that they need a new hub because damage to the original hub is unavoidable during removal. This is merely a guess at a possibility, nothing more. Nevertheless, consult with the shop which may do the press work if you are doing this job yourself.)
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Part # for idler pulley bearing rocket321 S-Series Tech 3 07-13-2013 10:30 AM
Wheel bearing part number for 04 ion brapple Ion General 13 11-30-2011 08:48 AM
Rod bearing part #? Av8r L-Series Tech 2 05-25-2011 02:45 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 10:16 PM
Front Wheel Bearing & Hub job Tips & Part #'s. CND_SC1 S-Series Tech 5 05-13-2008 10:37 AM
