Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 01-28-2016, 02:45 PM   #1
Dogman68
Dogman68 is on a distinguished road
Mad 99 saturn will not start and run
MY first post (please be gentle) my 99 Saturn has no fire to the spark plugs I"ve done all the suggested fixes such as new coil pack,ign.module checks as good crankshaft position sensor replaced cleaned grounds all fuses are good new plugs installed fuel pump and filter (eng. gets fuel) checked pcm looks good inside (no burn spots is very clean) new battery car has set for 6 years but I was able to start it on startig fluid but would not run besause of bad fuel pump hence the replacement but has not ran since If some body can help it would be greatly appreciated Dogman68 thanks
Add to Dogman68's Reputation
Rate the quality of this post and help Dogman68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dogman68 is offline   Reply With Quote
My Saturn won't start! Orville1 S-Series Tech 5 01-30-2016 10:05 PM
03 Saturn doesn't start periodically, but eventually does start Caveman1953 L-Series Tech 5 11-25-2011 10:15 PM
98 Saturn want start Sometimes Trigger S-Series Mods 2 02-15-2008 04:10 PM
1995 Saturn SL2 Start Porblems- I NEED A SATURN EXPERT! JamesDator S-Series Tech 33 10-30-2007 05:11 PM
Saturn won't start markus90000 S-Series Tech 2 08-24-2004 10:55 PM
