Old 01-17-2016, 07:05 PM   #1
Murphys_ghosy
Murphys_ghosy has a spectacular aura aboutMurphys_ghosy has a spectacular aura aboutMurphys_ghosy has a spectacular aura about
Murphys_ghosy's Avatar
1998 SW2
Dizzy Brake light ground issue
I'm on a tight schedule here so I need help ASAP!
After a heavy rain, I was driving home when suddenly my car died. Unable to use blinkers, hazards, etc. I was able to coast off of the highway and back to my house, but it is currently undriveable.
I'm 95% that it's the brake lights. With the car off, lights off, and keys in the ignition, the turning signals work. Hazards light it up like a Christmas tree; front turning signals alternate blinking with the brake lights. With the lights off, the car starts just fine. Pressing the brakes will stall the engine leaving a rich fuel smell.
I think a splice pack got wet from a bad seal and shorted out. Where is the rear splice pack? I don't have the time to just pull everything from my car so please help!!!
It's a 98 Saturn SW2.
98 SW2 - 184k
04 Bonneville SE - 215k
RIP
99 SL1 - 167k organ donor/future rat rod
99 SL1 - 300k towed to car heaven
Add to Murphys_ghosy's Reputation
Rate the quality of this post and help Murphys_ghosy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Murphys_ghosy is offline   Reply With Quote
Old 01-17-2016, 07:29 PM   #2
Default Re: Brake light ground issue
Given it's location I'd sooner think one of the bulb's on the hatch shorted out.
Between the driver side strut tower and hatch, on the floor under the carpeting.
File Type: jpg left rear ground splice pack location.jpg (48.3 KB, 6 views)
Old 01-17-2016, 08:22 PM   #3
Murphys_ghosy
1998 SW2
Thank you! That helps A LOT
As a test, I pulled the tail lights off. The car works without them and doesn't show signs of electrical failure (except for the burned out turning signal hyper blink). Judging from that diagram, the splice pack is right where I found a damp spot in the carpet.
98 SW2 - 184k
RIP
Old 01-18-2016, 03:28 PM   #4
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
The fuel pump grounds into that splice pack, which may explain why the engine dies when you hit the brakes (and unintentionally shut off the fuel pump).
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
Brake Light Issue Steviodaddio S-Series Tech 0 08-11-2010 10:29 AM
ABS/Brake Light issue Mcirella S-Series Tech 7 07-07-2010 09:29 AM
Brake Light Issue dbarlow183 S-Series General 1 06-21-2010 12:01 AM
Brake Light issue! xzn2p3 Vue General 4 05-24-2010 05:52 PM
3rd brake light Issue sprindl S-Series General 1 11-07-2005 07:33 PM
