Old 01-06-2016, 11:38 PM   #1
aesart
aesart is on a distinguished road
2007 ION-3 Quad Coupe
1999 SL
Dizzy High Idle Problem ,Throttle body, actuator solenoids
Greetings!
2007 Ion 3 Quad coupe 2.4L manual tranny, 196k miles - other than the sunroof this has been an AWESOME car!...
I was having low power mode when starting, and the cruise control hasn't worked for a few years now, and when I read up on it everything was suggesting the throttle body; most mechanics said to just replace it considering the miles as opposed to cleaning it. SO...
Got a new GM original throttle body, and read that I would probably experience a high idle as the computer would have been used to the old one, and there is a technique for the "relearning" process to go through, but the trouble is it won't go through it despite several efforts, including a trip to the dealer, who checked the vacuum systems and found no other issues - in other words it "should" be relearning but it won't...
We've tried the key on after battery disconnect, key on after code clearing AND battery disconnect (I have a device that clears all the codes), running for three minutes, shutting off, trying again, SEVERAL TIMES, I've actually driven it over 50 miles like this (to the dealer and back), NOTHING WORKS... I'm idling at 2800 rpm on average...
Now, one thing they and I both found were error codes for the two actuator solenoids on the top of the engine for intake and exhaust, which may or may not be the issue, but I'd like to replace them anyway (NOT with the dealer ala "price"), but I'm having problem finding the right GM part numbers...
Once again, this is a rare bird, 2007 (last year they were made), 2.4L gas with a stick...
So does anybody have access to the part numbers and tell me what they are for those two solenoids on the top of the engine? They are right next to each other and have plugs on top, one grey and the other black...
I think one's the camshaft actuator and the other one is for the variable valve timing...
Please, if you can help, life with children and one car is, well, not fun...
Thanks in advance!!!
Add to aesart's Reputation
Rate the quality of this post and help aesart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aesart is offline   Reply With Quote
Old 01-07-2016, 11:54 AM   #2
Default Re: High Idle Problem ,Throttle body, actuator solenoids
Tried these sites?
http://www.wholesalegmpartsonline.com/
http://www.gmpartsdepartment.com/par...?siteid=214533
Old 01-07-2016, 02:00 PM   #3
aesart
1999 SL
Thumbs Up Re: High Idle Problem ,Throttle body, actuator solenoids
Wow! Ask ye shall receive!
Found both of them on the fist site... Thanks!
Last edited by aesart; 01-07-2016 at 02:05 PM.. Reason: Wrong info in last post - removing...
Old 01-07-2016, 09:55 PM   #4
2006 ion2
2007 ION-2 Sedan
Pulling the battery and clearing codes has nothing to do with the tb relearning. Also, you hae no vacuum system, just a hose going to the brake booster. You tried leaving the key on, engine off for 10,15, 20 minutes? The throttle will move, then stop, then it's re learned. Your engine was used from 2006-2009 in every small to midsize car gm made.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-07-2016, 10:02 PM   #5
aesart
1999 SL
Idea Re: High Idle Problem ,Throttle body, actuator solenoids
Thanks, I'll try that! I have only left the key on for one minute at a time based on other threads I had read...
Question: I've heard not to manually move the throttle when it's powered up, but what about when it's off? (I haven't moved it yet for fear it might damage it). I've have the thought that if I moved it the computer would read that and correct it - thereby prompting it to start the relearning... Any comments? Do? DON'T?...
Much appreciate you replying to the thread!
Old 01-08-2016, 07:34 AM   #6
Yes, you are correct about throttle plate movement. With power off, the electric throttle can be opened manually for inspection, cleaning, etc.. When ignition is ON, electric throttles are powered up with throttle plate standing rigid; the ecm/pcm is sending commands to the electric servo motor to move the throttle plate based on four feedback sensors, two on throttle and two in the pedal. Once powered on the throttle plate is electronically controlled at all times so it's not recommended to physically move it. You can see throttle plate movement by having someone exercise the pedal while you observe throttle plate movement - observing a drive by wire system with the pedal/master telling the pcm to move throttle/slave.
Old 01-08-2016, 10:03 PM   #7
mitche
mitche is a jewel in the roughmitche is a jewel in the roughmitche is a jewel in the rough
mitche's Avatar
2006 ION-3 Sedan
If the high idle only started after replacing the new part there is a good chance you have an air leak, how did the rubber seal under the throttle body look?
Any possibiltiy the bolts were not tightened down in a crisscross pattern doing it in steps? Too tight? too loose?
Recheck all hose connections and electrical connections.
But all those things should have caused a code to appear.
Another thing to check, pull the inlet off and see if the throttle plate closes fully with key off, if it's hanging up for some reason.
I don't speed much anymore but I don't slow down for turns much either to keep the fun factor.
Add to mitche's Reputation
Rate the quality of this post and help mitche reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mitche is offline   Reply With Quote
Old 01-09-2016, 01:01 AM   #8
2006 ion2
2007 ION-2 Sedan
Moving the throttle plate power off will do nothing, the sensors in the tb follow the plate. DO NOT attempt to move the plate power on. When replacing the tb, the ecu has to learn the new sensors, which may have a slightly different relationship compared to the old ones. This is normal.
When you let a tb get dirty (on ions, they get very dirty)(who's a dirty tb, lol), the ecu compensates throttle position to reconcile maf based demands for a given throttle position, or the car wouldn't drive right with a dirty tb (they seriously get stupid dirty). When you clean the tb, nite the engine is getting more air than expected at a given throttle position, because the plate is held open farther to give it more air with a clogged tb that isn't clogged anymore. This is shay causes high idle when people clean an ion tb after too many miles (it should be cleaned every time you check your air filter), they get high idle and blame cleaning the tb instead of taking responsibility for their neglecting maintenance. Rant over.
Mitche, an air leak is possible, but the seals on these engines are very robust, and a re learn is required when installing a new tb, no matter what, or you get idle issues. Definitely something to check, though, if the relearn doesn't work.
2007 Saturn Ion 2
High Idle after Throttle Body cleaning tgggd86 S-Series General 2 12-19-2012 07:21 PM
high idle and SES after throttle body + EGR cleaning Troy35 S-Series General 25 02-26-2011 10:09 PM
high idle after cleaning throttle body shur35 L-Series General 2 04-05-2009 02:15 PM
2001 SL1 high idle after cleaning Throttle Body rickystarshine S-Series Tech 6 11-19-2006 08:33 AM
Sprayed throttle body to clean it now my idle is a bit high help Saturn 6 L-Series General 4 06-16-2005 06:50 AM
