Old 12-27-2015, 10:20 PM   #1
Rosstude
Rosstude is on a distinguished road
2002 SL
Default No fuel or temp gauge after starter change
Its been a while since I visited this site, my daughter had the car at collage for a few years and its been great until now. I have a 2002 SL1, and the starter went out. After changing it, now neither the temp or fuel gauge are working, they don't move at all. I removed the battery before changing the starter, and cleaned it and topped off the charge while on the bench.
All fuses check good, and everything else works.
Any thoughts?
Much appreciated.
Add to Rosstude's Reputation
Rate the quality of this post and help Rosstude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rosstude is offline   Reply With Quote
Old 12-27-2015, 11:14 PM   #2
billr
Default Re: No fuel or temp gauge after starter change
I gotta ask... are you sure those gauges worked before the starter change?
Add to billr's Reputation
Old 12-28-2015, 12:11 AM   #3
Those are single wire digital gauges. Disconnect battery NEGATIVE and let it sit with the headlight switch on for a couple of minutes then turn off headlights and reconnect battery negative and hope the BCM catches on and decides to talk to the cluster.
Old 12-28-2015, 03:59 PM   #4
Rosstude
2002 SL
Thanks for the process OldNuc, worked like a charm.
It started as a collage beater for my daughter, but we've grown fond of it and its MPG's, and are glad its whole again.
Old 12-28-2015, 05:13 PM   #5
That trick usually works and when it fails then it is new BCM time. Generally when doing any electrical work on a Gen-3 model disconnecting the battery negative is a very good idea, even if it does seem like it is required.
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Temp gauge change Dake S-Series Tech 6 05-01-2014 08:27 PM
Temp gauge not moving, replaced ECTS, no change... Ilwakeboarder87 Vue General 8 01-03-2014 10:46 PM
fuel and temp gauge failure WGBWGB62 L-Series General 3 06-22-2008 04:38 PM
1992 SL2 Fuel Gauge / Temp BullyCanadian S-Series General 3 05-28-2005 01:11 AM
