Old 12-08-2015, 06:52 PM   #1
EchoMirage
EchoMirage has a spectacular aura aboutEchoMirage has a spectacular aura about
EchoMirage's Avatar
Default no crank, good battery
first time it let me down since buying it.....95 sl2 auto, now has 42k miles. went to lunch at work, started fine, went to leave, and it wont crank. good battery, accessories work, its not getting juice to the starter. thinking ignition switch or neutral safety switch.
as it happens the tow truck driver had several saturns, and had to replace the ignition switch in every single one of them. before i order, any thoughts as to which it could be? is the ignition switch common enough that i should go ahead with that one? i jiggled both the key, and the shifter in park/neutral, and neither worked.
When tyranny becomes law, rebellion becomes duty
95 SL2 bought in 8/14 with 23K original miles
Add to EchoMirage's Reputation
Rate the quality of this post and help EchoMirage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EchoMirage is offline   Reply With Quote
Old 12-08-2015, 07:53 PM   #2
Default Re: no crank, good battery
Ignition switches are not a common problem to Saturns. Can you crawl under the car to measure the START signal for voltage on the starter? This may be the best way to test the ignition switch, wiring and Park.Neutral safety switch all at once. The starter has one small gauge purple wire that the ignition switch sends 12v power to the starter solenoid. Disconnecting this purple wire (safety while under the car) will allow you to measure it for 12 volts when someone turns the ignition switch to the START position; 12 volts should be on this wire as long as the key is held in START. Either you have 12v on this wire or not. No 12v = starting circuit problem. 12v on this wire = faulty starter.
Old 12-08-2015, 09:54 PM   #3
toggenburg
toggenburg's Avatar
Stick with Fdryer's advice.
No one I know has ever replaced any Saturn ignition switch, let alone with just 42K miles on it.
Besides, how long have you owned it?
Old 12-08-2015, 11:03 PM   #4
billr
I have replaced an ignition switch, but it would start the car OK, it was just fussy to get the key turning. Yeah, "go to the PPL wire"...
Add to billr's Reputation
Old 12-09-2015, 12:15 AM   #5
billysvue
^ what they said.
Load test the battery and measure voltages before throwing parts and labor at the problem.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-09-2015, 10:26 PM   #6
EchoMirage
EchoMirage's Avatar
year and a half.
the starter isnt getting juice. when i turn the key with the lights on, they dont dim. the neutral switch seems alot easier to change then ignition, ill try that first.
Old 12-09-2015, 10:48 PM   #7
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Troubleshoot this using fdryer's advice, but it sounds like you have a bad starter with a dead spot to me. The starter only draws power when it's engaged. Since the dead spot prevents the starter from engaging, you won't see the headlights dim.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 12-19-2015, 02:23 PM   #8
EchoMirage
EchoMirage's Avatar
i hit the starter with a hammer, and it cranked right over. took it out, left the battery disconnected for a week. replaced the starter just now....i ordered a valeo unit from rock, but i got something called a TYC.
hooked everything up; now, both my original starter and the new one have the post for the purple wire on the opposite side as the picture posted. theres still only 3 posts, and only one post the purple wire can hook to.
now it cranks, but WONT start. itll struggle, pop once or so, and keep cranking but no start.
does the battery being off a week have anything to do with it? it still has a full charge, everything else is the same. all i did was swap the starter.
Old 12-19-2015, 02:32 PM   #9
The battery being on standby does not affect why the engine won't start. It has more than enough capacity to power the starter motor so this is another problem. There are several things to try.
One is holding pedal to the floor and try starting again. The engine may have flooded with several failed starting attempts now that the starter was replaced. There's only one reason for flooding; the original two wire coolant sensor is made of plastic with a brass shell for mounting to the engine. Remove it for examination. Below are the two sensors with the flat nosed brass one the correct replacement to stop flooding and rich running problems.
Other issues may be related to spark or fuel pressure.
Old 12-19-2015, 02:39 PM   #10
EchoMirage
EchoMirage's Avatar
has to be no spark. i check the air filter, and tried spraying starting fluid directly into the throttle body, and nothing. didnt kick over at all. the ECT sensor was replaced last year with a brass one.
could i have knocked some wire or plug out? did something else just happen to break during this time?
Old 12-19-2015, 02:42 PM   #11
EchoMirage
EchoMirage's Avatar
well damn......floored the gas, and it started. ran rough, and its currently smoking out my garage, but its running right now. could the ECT still have gone bad?
Old 12-19-2015, 02:45 PM   #12
OK, if spark failed when starting fluid was sprayed, check for a blown fuse. To be absolutely sure spark failed, perform a spark test with coil wires remove. Have someone crank the engine while you observe for spark across the coil towers. And be sure fuel is injected; check for fuel at the test valve and remove spark plugs to check for fuel on them.
Old 12-19-2015, 03:10 PM   #13
EchoMirage
EchoMirage's Avatar
well its starting and running normally now, so i guess it was flooded. but does that mean the ECT went bad?
Old 12-19-2015, 03:49 PM   #14
Only if the connector is corroded from the original leaking coolant into the connections. If spark plugs weren't replaced, remove and examine them for wear and replace as necessary. If several starting attempts were made without the engine firing up, too much gas is injected to flood the engine. The reliability of EFI systems is recognizable by the instant start up in any weather condition as long as maintenance is kept up (plugs, wires, oil, etc).
Old 12-19-2015, 09:12 PM   #15
EchoMirage
EchoMirage's Avatar
plugs and wires were new at some point before i bought the car. the wires still look new, and i put about 20k miles since i bought it last august. the plugs still looked like new when i pulled one several months ago. at some point i was planning on doing new plugs anyway, just so i know when i put new ones in. the service history was fairly up to date when i bought the car, and even if it wasnt, it only had 23k miles when i bought it.
maybe it was just a fluke that it flooded this one time. ill see how it goes this week when i can finally drive it daily again.
05 ion replaced battery cable on crank marmitage Ion Tech 16 09-02-2015 02:12 PM
Won't crank - Battery brain teaser sajor S-Series Tech 15 07-13-2013 08:14 PM
Good battery, slow crank 64waves L-Series Tech 2 05-28-2012 09:30 AM
93 sl2 has battery won't crank zigstarre S-Series Tech 1 01-08-2009 06:08 AM
Battery Dies on crank frereagle S-Series Tech 3 04-24-2007 09:02 PM
