Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 10-21-2015, 07:29 PM   #1
rowdydog
rowdydog has a spectacular aura aboutrowdydog has a spectacular aura about
rowdydog's Avatar
2005 ION Red Line
Default 2005 Ion redline, needs idea on how much it worth
Someone is selling it has 209k miles , haven't driven it yet but if it in fair condition thinking about it, they are asking $3900, its black ext.is ok some scraps and chips but no big damage, interior is good but they used way to much deodorant lol. Just wondering about price, looks like they are above KBB and NADA asking price on it, any ideas???
Add to rowdydog's Reputation
Rate the quality of this post and help rowdydog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rowdydog is offline   Reply With Quote
Old 10-22-2015, 11:57 AM   #2
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: 2005 Ion redline, needs idea on how much it worth
What is KBB value?
I would shoot an offer for either at or slightly below the KBB value just to see if they will budge on it.
I cant say what to shoot for as idk what the value is.
209k miles seems to a bit high to buy tho, then again, these engines are reliable.
a test drive is needed tho.
if it drives smooth, and theres no unusual noise to it, then you can shoot for kbb value or slightly under.
in this case as far as condition, based on your description, id would base off of the good or fair condition. only way it would fall under excellent is if its like new, which is it far from.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-23-2015, 10:38 PM   #3
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
3900?
I paid 2700 for mine with 124k on it.
Id say 3500 at most if its stock, 3k if its modded.
And I only say lower if its modded because you don't know how hard they beat on the car.
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 10-24-2015, 07:55 PM   #4
rowdydog
rowdydog's Avatar
2005 ION Red Line
Well I bought, lady owned, she's said she owned since 16k, all stock, changed clutch once, timing chain, got it up on my lift, seems lower control arms are worn, sway bar endlinks rattle some, probably needs plugs too, suggestions for best ones? gonna do fuel filter too. got it for $3100, oh it has the coolant light best way to fix? friend's got and Ion too and has same problem
Old 10-24-2015, 08:50 PM   #5
billysvue
Well I bought,
T/belt changed when? CHnage all fluids....
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 10-24-2015, 11:29 PM   #6
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Coolant light is the sensor. Its built into the tank itself, so you need to replace the whole thing.
Endlinks, use Moog.
Get fe5 control arms (08-10 SS) with spherical bushings from Crate engine depot.
Use NGK copper plugs. They don't last as long, but they are better for boosted motors.
When you are ready to start modding it, let me know. Stock gets boring quick.
Old 10-26-2015, 09:01 AM   #7
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
the sensor may be dirty, like mine might be.
you can bypass the message by jumping it with a wire (like I did), but then you will have to periodically check the fluid (should check all fluids periodically anyways, right?)
try taking the coolant tank out and swishing soapy water in it can clean the sensor too.
if needs replacing, as specified, you need to replace the whole tank.
if you try to replace just the sensor, autoparts stores will just look at you funny.
Plus it cannot be easily removed from the tank either
03 ion-2 Sedan 5sp
♕KCCO
Old 10-26-2015, 03:07 PM   #8
rowdydog
rowdydog's Avatar
2005 ION Red Line
Yeah I have had saturns before, but never an Ion, I'll try the soap but doubt it will work, I did install a Stainless Steel grill off a redline Vue in the opening and painted the foglight closures silver, just for the heck of it,
Old 10-26-2015, 04:39 PM   #9
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
I also have the stainless steel grill (didn't know the Vue used the same size). It matches the color the inserts faded to from the original black.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
Old 10-26-2015, 05:37 PM   #10
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
The mesh grille doesn't look bad. Mine is horizontal bars in silver with a black accent.
You should probably look into the fog lights, as lighting is horrible with the coupes.
Don't know why you don't have em, I thought they started coming with them in 05.
And black is the best color, by the way
oh, and in the next week or so I will have a K&N intake for sale if youre interested. I am upgrading to a zzp 3 in.
Old 10-26-2015, 07:56 PM   #11
rowdydog
rowdydog's Avatar
2005 ION Red Line
Well I built Saturns for 16yrs, worked at the plant, there are different levels, 1,2,3, I think. they keeped the gauges under lock and key I hear. we had so many come down the line didn't have time to keep up, lol. I did change plugs, fuel filter, and cabin filter, it was black never been changed, most people don't know enough about their cars to check or read the manual. I do have new headlights coming, mine are bad, new struts and shocks, and control arms, end links etc. Drives great for a 200k car all the plugs looked the same, no oil evident on them. ? how do u drain inter cooler remove hose? thinking of flushing it along with the radiator and clean tank see it sensor starts working, rockauto has them for $34 I think.
Old 10-26-2015, 08:40 PM   #12
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
What shocks/struts did you go with? fe5 I hope. Fe3 isn't bad, but Fe5 is just a lot better overall. Same with control arms, along with spherical bushings.
Ill put money on it that your intercooler needs to be rebuilt. Its a common thing that they only last 50-60k on em. My buddy rebuilt mine in like 20 min, and my temps dropped 60 degrees. Super easy to do. Your intercooler is ran through the motor coolant as well.
When you change the air filter, use a k&n/spectre unless you look into a full intake.
And yes, they have level 1, 2, 3, Redline.
Feel free to message me with any questions man.
Old 10-27-2015, 05:35 PM   #13
daver
daver's Avatar
2005 ION Red Line
To my knowledge, the Red Lines never came with fog lights.
I also had to buy a whole new center console in order to get an armrest.
Old 10-27-2015, 06:11 PM   #14
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
What? They were definitely standard issued in at least 06/07. It might of been late 05 they started it.
I have fogs in mine, and so do most of the locals (besides the 1 with an 04)
Redlines did not come with an armrest. They only came in the base models.
I think I have 2 extra's of those if anyone needs one.
Old 10-28-2015, 08:48 AM   #15
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
iv added fog lights onto my ion sedan, and it made a huge difference in lighting.
the ones I found, however, do not have the tiny chrome bulb covers inside the assembly, so light coming from the fogs go everywhere, especially with the fact I have HIDs in them.
I wish I can open them and paint them black to match, which will also help reduce the amount of glare, but I think they been opened before, and permanently resealed. they may have been opened to remove the bulb covers, might get another pair later on.
03 ion-2 Sedan 5sp
♕KCCO
Old 10-28-2015, 04:53 PM   #16
daver
daver's Avatar
2005 ION Red Line
Yeah, mine was built in April, 2005, and no fogs.
Old 10-29-2015, 01:48 AM   #17
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Add em. Youll love night driving a lot more.
Old 03-26-2017, 08:10 PM   #18
macantley
macantley is on a distinguished road
wow, 3900 for one with 209k miles, i realize this post is pretty old, but i would think thats atleast $1000 more than it was worth unless it was in extremely good shape.
Add to macantley's Reputation
Rate the quality of this post and help macantley reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macantley is offline   Reply With Quote
Old 08-30-2017, 03:54 PM   #19
rowdydog
rowdydog's Avatar
2005 ION Red Line
Well I got it 4 $3100 actually, had to buy a intercooler pump $89 for a bosch at Amazon. Need a sunroof Mine finally broke, would love to get it fixed
Whats an 04 Redline Worth? Saturndude82 Ion Red Line 12 04-28-2011 08:54 AM
Considering purchase of a 2002-2005 Vue..worth it? ionmy1 Vue General 4 04-30-2009 01:15 PM
2005 VUE Redline vs 2009 VUE Redline SHMOKE Vue Red Line 27 03-22-2009 10:19 AM
04 redline worth this much? veritasconnor Ion Red Line 4 07-19-2006 09:37 PM
Interior of VUE redline, an idea saturnd00d Mods and Performance 1 04-24-2003 06:04 PM
