Old 10-21-2015, 11:38 AM   #1
Kelevra
Kelevra is on a distinguished road
Dazed 99 Saturn SC2 Steering issues this morning
Ok, so I searched the forum and didn't see anything... So here goes:
My SC2 was acting real weird this morning. It was about 35-40 degrees when I left, and I had difficulty turning the steering wheel. Then after I got back home from a short trip (about 10 minutes each way) the steering acted just fine. I let it sit for a while and had to go back out, about 55 outside, and the steering was acting stiff again, I had to make a tight turn to the right and there was a pop sound, but now the steering acts like it should again. I stopped my AutoZone while I was out and the clerk did some research on the computer and said it sounded like a problem with the Rack & Pinion. Does this sound like an accurate guess? If so how bad could this be to fix?
Add to Kelevra's Reputation
Rate the quality of this post and help Kelevra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kelevra is offline   Reply With Quote
Old 10-21-2015, 08:17 PM   #2
bluesl2
bluesl2's Avatar
Default Re: 99 Saturn SC2 Steering issues this morning
It's kind of hard to say exactly without seeing the car. If you can it would be a good idea to have a shop(dealer or independent), look at your steering/suspension components if you can't yourself. It sounds like maybe the rack or the bearing in the intermediate steering shaft may be binding although on an S-series I've never seen one do that. I would also closely inspect the subframe and lower control arm attaching point areas.
Add to bluesl2's Reputation
Old 10-21-2015, 08:26 PM   #3
Pitcher
Pitcher's Avatar
Did you check the power steering fluid? Is it full? Or is it original?
May not be that, but check into it anyway.
'98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP
Taking Care of a '01 SL2 10th Ann. Ed. "Silver Salute" Mobil 1 AFE
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-21-2015, 08:27 PM   #4
Kelevra
I wouldn't really know what to look for. So I will have to take it somewhere if the problem persists. Though I did notice there is a build up of some kind of greyish sludge in the driver side wheel well. I noticed this before when I first got the car and cleaned it out, but now it's back. Not sure if it's related or not.
Old 10-21-2015, 08:28 PM   #5
Kelevra
That was my first guess. Doing fine on that.
Old 10-22-2015, 04:35 PM   #6
bluesl2
bluesl2's Avatar
The sludge in the wheel well may be a clue, you might have a torn cv boot causing the grease to be flung out. Although cv joint grease is usually a turquoise color.
Old 10-22-2015, 06:06 PM   #7
Kelevra
Yeah... Definitely torn...
your morning Saturn LoL.... SLfun S-Series General 6 09-13-2015 05:29 PM
2001 Saturn L300 - Steering issues L300v6 L-Series Tech 8 12-16-2014 11:24 PM
1995 Saturn Sc Steering Issues bbubel S-Series Tech 18 04-22-2013 08:43 AM
2003 Saturn Ion - Steering issues Dr. X Ion General 11 01-13-2012 03:44 PM
2003 Saturn VUE - Security Light & Power Steering issues Bridgette Vue Tech 5 10-29-2007 02:46 PM
