Old 09-24-2015, 03:12 PM   #1
hwieczerza
hwieczerza is on a distinguished road
Default 2008 Vue questions
I recently had the 35r plate problem on my 08 Vue XE AWD. I opened the side cover and went ahead and replaced all the wave plates but 1234 (don't ask why). Filled with proper fluid while warmed up, put it in D or R and works fine.... for only about 30secs. Then I hear a rattle and eventually it goes nowhere ( I am guessing the TCM is shutting it down). I went back in and checked everything and it all looks perfect, I even watched the UTube video about 100 times and I am certain I did everything right.
I'm guessing filter clogged? or bad pump? I did not completely pull the trans so I didn't get into that area. I was able to "sneak" everything out through the wheel well.
Also, I have access to a 2010 Equinox 6T70 w/ MH4 option and 2.77 final drive, which are the exact specs I have. Any reason I cant swap for that trans? THANKS!
Add to hwieczerza's Reputation
Rate the quality of this post and help hwieczerza reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hwieczerza is offline   Reply With Quote
Old 09-24-2015, 04:09 PM   #2
satlite440
2001 SL2
Default Re: 2008 Vue questions
um ya.your filter is plugged...if you looked at my o/h thread on this trans you will see why you need to split the case and do it right...shortcuts are not shortcuts on auto trannys.
Old 09-25-2015, 07:08 AM   #3
hwieczerza
Thanks for the reply. Is there anything special about splitting the cases I should know... Open it vertical or horizontal matter?
Old 09-25-2015, 07:24 AM   #4
hwieczerza
I have searched for your o/h pics with no luck. Can you point me in the right direction? Thanks again.
Old 09-25-2015, 11:41 AM   #5
satlite440
2001 SL2
http://www.saturnfans.com/forums/sho...ght=6t70+o%2Fh
you didn't look
Old 09-26-2015, 07:42 AM   #6
hwieczerza
Great tread, info, and pics! I did look but I guess not in the right place. Thanks again!
Old 09-26-2015, 09:49 AM   #7
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
there is a specific thread for 2008 and newer Vue. The Vue of that era is actually an Opel product so a somewhat different animal than prior to 2008
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Oil filter removal questions 2008 4 Cyl Vue JohnASmith 2008 Vue 8 08-24-2013 02:17 PM
2008 VUE v6 Oil change questions muminiasty 2008 Vue 1 06-18-2012 10:04 PM
I am thinking of getting a 2008 Vue. I have questions. SJ Wolf 2008 Vue 2 06-24-2008 09:38 PM
2007 vs 2008 questions destro23 2008 Vue 2 01-24-2008 07:37 PM
2008 model questions agoldslsaturn 2008 Vue 31 07-20-2006 09:01 PM
