Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 08-29-2015, 09:50 AM   #1
EBonn95
EBonn95 is on a distinguished road
2004 ION-3 Sedan
Default 2004 Ion Sedan 2.2 lowering springs
Hey guys, I'm new here. I have an '04 Ion sedan 2.2 with an auto tranny and I'm trying to get a 1.5-2" drop. I've been reading a lot of posts about this already but it sounds like there are a lot of different brands that people use. What springs should I get and how long can I expect my stock struts to last?
Thanks
Add to EBonn95's Reputation
Rate the quality of this post and help EBonn95 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EBonn95 is offline   Reply With Quote
Old 08-29-2015, 12:03 PM   #2
billysvue
Default Re: 2004 Ion Sedan 2.2 lowering springs
https://www.google.com/search?q=04+I...2+megan+racing
"Model Number : MR-LS-SIO03
Spec:
- Color: Orange
- Lower rate: 2" Front, 1.7.5-2" Rear
- Springs rate: 300F & 250R..."
http://www.meganracing.com/products/...d=513&catid=44
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 08-31-2015, 01:58 PM   #3
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Spec:
- Color: Orange
exactly what i have.
the stock strut will not be able to handle the increased load you will put on them with the springs.
you have a couple options as far as shocks/struts:
-find someone parting out a ion redline and buy the used FE5 shocks/struts off of it, and replace the springs.
-go online (rockauto is usually the best place to go) and order new FE5 shocks/struts
-go online and order aftermarket shocks which will more than likely be able to handle lowering springs.
I went with buying aftermarket shocks
i got KYB Excel-G shocks, ordered the complete set advertising to fit a cobalt (ions and cobalts use the same suspension), and put the megan springs on them.
I ended up reusing the old top mount from my old front struts, but its recommended to replace those with new ones too.
After installing, at first, they will seem stiff for the first few thousand miles, but over time, they will get comfy with the setup.
i replaced mine 50k miles ago, and the ride is still great
an FYI, since you will be having the suspension apart, you can get the swaybar bushings (19mm i think), swaybar endlinks (K80252), and tie rod ends (ES800030) replaced with Moog parts. That way, youll will only need to get an alignment once, instead of needing one after replacing each thing.
if you dont get an alignment after lowering, youll suffer from camber wear on your tires.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-19-2015, 10:23 PM   #4
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Eibachs or progress.
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 09-22-2015, 12:52 AM   #5
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
SSC springs
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 09-22-2015, 06:45 AM   #6
billysvue
the stock strut will not be able to handle the increased load you will put on them with the springs..
Springs don't increase the load- adding weight does.
That said I wouldn't go through the hassle of changing springs, though ,without installing new struts and shocks.
'17 Suby Forester
Old 09-23-2015, 01:46 PM   #7
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
increased load coming from the car riding lower than what it originally was.
03 ion-2 Sedan 5sp
♕KCCO
Old 09-23-2015, 10:43 PM   #8
06_Ion2
06_Ion2's Avatar
I had 60k on stock shocks without any problems on eibachs. I don't see a problem, you could run the fe3 shocks.
Old 09-24-2015, 02:32 PM   #9
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
I don't know which shocks I had, whether is they were fe1 or fe3.
the shocks were due to be changed anyways, so I went with a new set I knew could handle a lowered ride.
03 ion-2 Sedan 5sp
♕KCCO
Old 09-24-2015, 08:50 PM   #10
Clyderp
Clyderp is on a distinguished road
2007 ION-2 Sedan
Has anyone ever tried Road Magnet? They are one of the few springs I have found that say they are specifically for the Ion sedan.
Add to Clyderp's Reputation
Rate the quality of this post and help Clyderp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Clyderp is offline   Reply With Quote
Old 09-25-2015, 09:26 AM   #11
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
never heard of them myself.
basically, if you find springs to fit a cobalt, they will fit the ions too.
youd prolly have better luck finding a set listed to fit a cobalt than an ion.
the megans I have were listed for ions, and I got about 2" drop front and back.
I remember seeing on ebay a set of adjustable lowering springs for the ions that give a max of 4" drop, but I haven't seen any in a while.
I don't remember what brand they were, but all I remember is that they were blue.
03 ion-2 Sedan 5sp
♕KCCO
Old 10-27-2015, 02:34 PM   #12
Clyderp
2007 ION-2 Sedan
If I put in lowering springs with fe3 shocks and struts would that lower the car anymore than just putting in aftermarket shocks and struts?
Old 10-27-2015, 03:30 PM   #13
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
[QUOTE=kevin.st56;2159927]
[QUOTE]
Wrong. Not an exact fit. You need an adapter kit for them to work with our struts.
Don't use cheap no name springs and expect good ride quality.
Shocks and struts don't decide the ride height, completely.
They just determine how stiff your ride is. And absorb the roads.
I believe the fe3 on my base model is the perfect balance. Fe5s would be good if you like the ride a bit stiffer.
Old 10-28-2015, 09:44 AM   #14
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
I know the shocks are the same, but I guess the springs aren't.
03 ion-2 Sedan 5sp
♕KCCO
Old 10-29-2015, 01:45 AM   #15
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Shocks and struts are. Springs and top hats are not.
Old 05-03-2016, 05:33 PM   #16
Hayhay63
Hayhay63 is on a distinguished road
i've had megan racing springs now for a year
stock struts and shocks are now going bad
im in the process of looking for an upgrade
not sure what to get
Add to Hayhay63's Reputation
Rate the quality of this post and help Hayhay63 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hayhay63 is offline   Reply With Quote
Old 01-12-2017, 11:28 AM   #17
bengrantham
bengrantham is on a distinguished road
cobalt coilovers, i doubt you will be satisfied with just springs
Add to bengrantham's Reputation
Rate the quality of this post and help bengrantham reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bengrantham is offline   Reply With Quote
lowering springs redgt03 Ion Mods 8 12-09-2013 07:47 PM
Lowering Springs nriebel Ion Mods 21 04-04-2011 10:06 PM
CM lowering springs, for sedan or coupes????? kaviation Ion Mods 11 09-27-2007 12:27 PM
Saturn ION Sedan Lowering Problem djiseemike Ion Tech 4 06-29-2006 11:14 PM
