Old 08-28-2015, 10:14 PM   #1
jasenpeters
jasenpeters is a jewel in the roughjasenpeters is a jewel in the roughjasenpeters is a jewel in the rough
jasenpeters's Avatar
Default Headlight - Flip/Pop Up Type
Yes, my time has come too.
Noisy rattle on close, like the motor did not get the signal to stop, then stops.
I know I can replace the gear, and I will, but....
Does anyone know how this electro-mechanical circuit works?
What tells the motor to stop? And if teeth on the gear are broken, why does the motor keep going, but after a while stops?
Also, is it ever the case that this happens after opening?
Opening is okay for me. So that may have to do with where the teeth broke on the gear.
I can't find the post now (I suck with the search engine), but someone said they would post the circuit if asked. I'm askin'.
(Thanks to mramay for the pic)
Re-Animated: 2015-08-18, 220,497 + 21,000 Miles
1996 SC2 DOHC, Manual, 220k, 36mpg Hwy
Add to jasenpeters's Reputation
Rate the quality of this post and help jasenpeters reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jasenpeters is offline   Reply With Quote
Old 08-28-2015, 10:29 PM   #2
Default Re: Headlight - Flip/Pop Up Type
Hope these help, though I don't believe they describe exactly how the controller knows the doors are up or down.
1994 SC 2 Flip-up Headlight Assemblies RobKeane S-Series Tech 2 09-15-2012 09:38 PM
quick question about flip up headlight buckets (hid retrofit incoming) k0ba1t S-Series Mods 2 08-15-2012 04:47 AM
Flip Up Headlight Assembly lhwilliams Community Center 0 04-14-2007 08:19 PM
*wanted* intake to alternator brace & flip headlight bracket Mr Bill Classifieds 0 09-26-2004 10:10 PM
flip-up headlight problem midnightsc2 S-Series Tech 0 11-19-2002 11:57 AM
