Go Back   SaturnFans.com Forums > Site Information > Community Center > Introductions & Greetings
Old 08-18-2015, 08:49 AM   #1
bzjht
bzjht is on a distinguished road
Default hello, new to site. Questions on battery cable
I have a 2000 sl2. I am having issues with battery cables keeping connection. The positive terminal has 2 cables connected. Anyone who I have asked about this is stumped. It has both and red and black cable connected to positive side. I am not sure why and what to do about this. I have had to replace the post with a bolt in order to keep some sort of connection. ANY ideas would be greatly appreciated.
Add to bzjht's Reputation
Rate the quality of this post and help bzjht reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bzjht is offline   Reply With Quote
Old 08-18-2015, 10:50 AM   #2
cityhawk
cityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to all
cityhawk's Avatar
1993 SW2
2001 L-Series 3.0L Wagon
Default Re: hello, new to site. Questions on battery cable
Welcome to Saturnfans.com!
My positive terminal looks different than that, but I have a first generation S-series (1993 SW2). That's an interesting solution for the terminal. Did you do that because you needed more length, or because the old one stripped? If the latter, you can get replacement terminal posts at your FLAPS (friendly local auto parts store).
You will get more luck if you post your question in the S-series tech forum as many more people will see it.
Saturns:
1993 SW2 MT 182,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
Old 08-18-2015, 12:28 PM   #3
As suggested, repost in the S-series tech forum where more members can contribute or remain here with whatever suggestions are given. The extra (black) cable attached to the red battery terminal may be an aftermarket addition - auxiliary power to something you have in your car that isn't stock unless its a second cable connected to the starter. There may be problems down the road if this connection works loose from the tight confinement area and normal engine/road vibrations rattling the connection. If this black cable isn't needed and goes nowhere, disconnecting it will put less strain on the battery terminal. If its needed, perhaps combining the two cables into one battery terminal lug can be a cleaner set up and replacing the bolt with the correct bolt can prevent damaging the battery. Since side terminal batteries suffer more damage from overtightening, a damaged side terminal adds to problems. Your battery cable connections are not normal. Normal is one large cable/lug per side.
It shouldn't be difficult to trace the black cable once all battery cables are disconnected and battery removed for better viewing of cable routing.
Replace Battery Cable LelandC Aura General 3 10-06-2013 10:55 PM
Negative Battery Cable Is Hot.... rollin_96 S-Series Tech 32 09-22-2012 06:45 PM
2000 SL2...battery and battery cable? zulaya S-Series Tech 8 03-28-2007 02:22 PM
need to run cable from trunk to battery tsc Ion General 14 02-28-2006 08:14 AM
