Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 08-15-2015, 01:24 PM   #1
jakeb
jakeb is on a distinguished road
2005 L-Series 2.2L Sedan
2007 ION Red Line
Default 2007 Ion smoked and died
I have only had this thing for a few days and knew that it was a serious project - the car smoked, but very little, when I picked it up. and was throwing p0304.
It's a 2007 redline no comp package, 127k
Just after I bought it, before I drove it home, I put a bit of seafoam in the gas. When I got home (30 miles) I shut the car off, started it back up, and the check engine light was OFF. I thought maybe the seafoam had knocked something lose in an injector or something and worked around the issue.
It was parked for the last few days while I replaced the hubs/wheel bearings. Finished that up and took it for a spin. It smoked pretty bad when I fired it up (valve seals?) and down the road. I turned around about 300 yards from my house and while turning it started smoking significantly worse - couldn't see out the back window - and died. Check engine light then starts blinking (lol)
So, what do you think I'm looking at here? I know the head is probably in bad shape - the existence of the code for a long time could burn a valve if that issue lead to a lean condition in a cylinder, right? I have owned a few supercharged cars and have never had them lose oil into the motor - does that happen with these?
After the car completely cooled off I cranked it over and it spun fine, but wouldn't putt. I'll do a compression test when I get it pulled home.
Think the lower end could also be an issue here?
07' Saturn Ion Redline (For Sale - needs work)
06' Saturn Ion 2 (Totaled by rear collision 8/9/15 @ 137k)
07' Pontiac Solstice 2.4 Stage 3 DDM Supercharged (Summer)
Add to jakeb's Reputation
Rate the quality of this post and help jakeb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jakeb is offline   Reply With Quote
Old 08-15-2015, 01:52 PM   #2
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
Default Re: 2007 Ion smoked and died
Start with a compression test.
What color is the smoke?
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 08-15-2015, 03:15 PM   #3
jakeb
2007 ION Red Line
The smoke was white. No low coolant light (yet) but didn't check the fluid when I left the car.
Old 08-16-2015, 08:19 PM   #4
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Head is probably shot then if it just smoked and died.
Check the fluid and check the oil.
Old 08-17-2015, 01:28 AM   #5
2006 ion2
2007 ION-2 Sedan
You poured seafoam "into it". I see you enjoy being specific. Seafoam has many "applications", where did you pour it into? How much? What code(s) does/do the car have? Seafoam, mmo, and other cleaners when poured into the sump or intake smoke like crazy.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-17-2015, 01:48 AM   #6
bern
2004 ION-2 Sedan
"smoked and died" Shouldn't smoke
Add to bern's Reputation
Old 08-17-2015, 08:39 AM   #7
2006 ion2
2007 ION-2 Sedan
Unless they poured seafoam into the intake or sump. Then it'll smoke and die.
2007 Saturn Ion 2
Old 08-17-2015, 01:05 PM   #8
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
iv seafoamed the civic we have, only pouring a third of the can into the vacuum lines, and that made it smoke quite a bit, but running it for a while cleared up eventually
how much of the seafoam did you pour, and where?
it sounds like you put too much seafoam and bogged it down.
its recommended to only pour a third of the can in fuel, vacuum, and in oil before performing an oil change.
before making assumptions tho, get that comp test done, and fluids.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-18-2015, 06:32 PM   #9
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
If youre within 2-3 hours of me, ill buy the car from you.
Old 08-20-2015, 10:18 AM   #10
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
His location states hes from Wisconsin.
Your out of luck there lol
03 ion-2 Sedan 5sp
♕KCCO
Old 08-22-2015, 12:42 AM   #11
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
It wasn't there when I originally asked. Haha
Old 06-28-2018, 02:28 AM   #12
Alexferguson
Alexferguson is on a distinguished road
So I finally got my new replacement pump from amazon $95 bucks, after swapping them out I took the old one apart and found that the steel bell was broken into 4 pieces, the impeller is magnetic driven, see pic, also I am thinking about doing a color change when I paint it, black now, want something that pops but not to bright, haven't decided on when to do it but I know less than 6 k where built just thinking ahead
Add to Alexferguson's Reputation
Rate the quality of this post and help Alexferguson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexferguson is offline   Reply With Quote
smoked corners redlineit Vue Red Line 3 03-25-2008 01:03 PM
I think my RDM is smoked! turbotoad Vue Tech 3 01-06-2008 08:16 PM
ION QC Smoked Taillights trancer78 Ion General 5 03-06-2006 03:32 PM
I Smoked A New Volvo! zallen777 Ion General 10 09-17-2003 05:29 PM
New Ion gets smoked! piratepress Ion General 40 09-16-2002 05:34 PM
