Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 08-05-2015, 07:10 PM   #1
herp444
herp444 is on a distinguished road
herp444's Avatar
2006 RELAY-3
Default 06 relay front turn bulbs
having a interesting issue with the relay. dash tells me the turn signal is out. pull the headlight and the bulb is fine. put it back into bulb holder and works fine. has happened a couple times. the last time it told me both were out. did the drivers side bulb unplug/plug and then both sides started working properly again. fuses are fine, wires look fine. just wondering if anyone else has had this problem and what they did to fix the issue.
Add to herp444's Reputation
Rate the quality of this post and help herp444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
herp444 is offline   Reply With Quote
LED Taillight and Turn Signal Bulbs SL19302 S-Series Tech 3 10-22-2014 08:43 AM
2007 Relay Front Turn Signal Replacement jessabug78 Relay Tech 1 04-26-2011 02:13 PM
Turn signal bulbs s-seriesguy Ion Mods 11 09-10-2009 10:33 AM
Sylvania Turn Signal Bulbs oldbess96sl2 S-Series Mods 15 08-22-2007 04:06 PM
turn signal bulbs.... twizted_ion Ion General 15 05-28-2006 10:43 PM
