Old 06-27-2015, 04:27 PM   #1
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
Default Replaced Battery Cable, Car wont start
I just replaced the positive battery cable on my daughter's 2005 Saturn ion and now it won't start. It started before I changed it out. Lights come on when I turn the key, but the car does not turn over. The dash lights go dark when I turn the key, and then come back on when I stop turning it.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
Old 06-27-2015, 04:45 PM   #2
billysvue
Default Re: Replaced Battery Cable, Car wont start
Double check your work, as well as removing ground cable clamp, cleaning and replace.
What's battery voltage?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-27-2015, 05:10 PM   #3
marmitage
marmitage's Avatar
I cleaned all of the connections and im unable to figure out the voltage because I don't have a volt meter. I did swap out the battery with a fully charged battery to see if the previous battery was dead. Same thing happened with the fully charged battery. The other battery was able to start a different car.
marmitage
99 Sw2 Daily driver
Old 06-27-2015, 06:41 PM   #4
Originally Posted by marmitage View Post
I just replaced the positive battery cable on my daughter's 2005 Saturn ion and now it won't start..... Lights come on when I turn the key, but the car does not turn over. The dash lights go dark when I turn the key, and then come back on when I stop turning it.
This suggests a power problem with either red/positive or black/ground battery cable connections. Examine your repairs again, carefully.
Old 06-27-2015, 09:39 PM   #5
The complete positive cable from the battery in the trunk to the fuse block under the hood? Lot of work.
Check the tightness of the cables at the battery and the underhood fuse block.
Add to ssicarman's Reputation
Battery died now car wont start babygirlnes Ion Tech 11 01-15-2013 07:46 PM
95 sl2 wont start , just replaced timing chain robul S-Series Tech 11 12-17-2012 08:24 PM
car wont start. battery? gapessos S-Series Tech 10 01-09-2012 05:06 PM
94 SL2 wont start - no spark - Replaced CPS mashley S-Series Tech 9 12-03-2011 05:16 AM
03 vue replaced transmission, now wont start vue2.2 Vue Tech 10 10-04-2011 01:09 PM
