Old 05-18-2015, 06:35 PM   #1
Tajee
Tajee is on a distinguished road
Default 2008 Aura XE 3.5 Error Code Issue
Hello,
I have a 2008 Aura that went in for new starter today. When I picked it up and started driving maybe 1/2 mile from the mechanic I see the check engine light and service ECS lights on. I drove the 2 miles home and also noticed the transmission wasn't shifting properly. It was very jerky like it was stuck in one gear.
Once home I plugged in my engine code reader and it came up with (11) error codes. (Car had no issues or codes before I dropped it off for the new starter)
Below are the codes. Any help would be greatly appreciated.
B2AAA
U0100
U0073
P1627
P1018
C3318
P0751
P0705
P0603
P0602
PO601
The codes seem to be all over the map.
Thanks
Add to Tajee's Reputation
Rate the quality of this post and help Tajee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tajee is offline   Reply With Quote
Old 05-19-2015, 06:52 AM   #2
gpartrid
gpartrid will become famous soon enough
gpartrid's Avatar
2008 AURA XR
2008 SKY Red Line
Default Re: 2008 Aura XE 3.5 Error Code Issue
I'm not a DIYer but you could give this site a try for some of the codes. http://codekeyunlock.com/default.asp
I'm certain some of the knowledgeable folks will offer their insight as well.
2008 AURA XR
Ocean Mist
Sunroof
Loaded!
Built: 07/19/07
2008 SKY RL
Silver Pearl
Black on Black
6 Disc w. Monsoon
Chrome Wheels
4 Pedals
GMPP Turbo Upgrade & CAI
Built: 09/20/07
Add to gpartrid's Reputation
Rate the quality of this post and help gpartrid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gpartrid is offline   Reply With Quote
Old 05-19-2015, 09:33 AM   #3
Tajee
What would cause all these error codes all of a sudden? Could they have shorted something out when they did the starter?
Old 05-19-2015, 09:59 AM   #4
This may be a coincidence of replacing the starter when the battery was disconnected and your battery is worn out(?) or loose connection. Check for loose battery connections first. Next is a battery test its several years old, at your favorite auto store. Third, if not close to state inspection, try resetting these error codes wait for any to return. Hopefully this was just a loose battery connection (hope for the best) and not something more (anticipate the worst).
Old 05-19-2015, 10:28 AM   #5
Tajee
Thanks for the info.. The battery is brand new only 1 week old.
Old 05-19-2015, 10:44 AM   #6
..... Next is a battery test its several years old, at your favorite auto store. ..
This should have been "Next is a battery test if its several years old..." I hate proofreading but understand the slight interpretations given when it can appear against what was intended.
Old 05-19-2015, 12:51 PM   #7
greenman
2009 AURA XE
Originally Posted by Tajee View Post
Hello,
i'm assuming u had a no start or intermittent no start condition so u replaced battery & then starter. right?
Add to greenman's Reputation
2008 Astra XR 4-Door, Rough Idle & Error Codes IMay1280 Astra Tech 15 01-07-2016 11:00 PM
2008 Vue 2.4L Thermostat Error Code Really?? Vue Tech 4 01-22-2014 05:03 PM
Error Code PO 442 slv01sc2 S-Series General 29 08-24-2013 06:31 PM
Aura XR P0449 Error Code shadowhsc Aura General 7 06-01-2012 09:20 PM
2008 Saturn Aura XR DTC code P0303 auraXRguy08 Aura General 2 01-21-2012 10:00 PM
