Old 05-18-2015, 06:12 AM   #1
mrdoiturself
mrdoiturself is on a distinguished road
Default 03 Vue won't start sometimes
I have a 2003 vue 3.0 v6. Every once in a while it won't start. It cranks and turns over like normal but does not start. When this happens I have to turn the key to the start position and wait for half a minute then start I it up and she starts right away. Anyone have any idea what might cause this?
Add to mrdoiturself's Reputation
Rate the quality of this post and help mrdoiturself reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrdoiturself is offline   Reply With Quote
Old 05-18-2015, 08:21 AM   #2
Default Re: 03 Vue won't start sometimes
Mileage, maintenance done parts replaced? Spark plugs are recommended for replacement every 100k miles. A quick fuel pressure test can be done by turning on ignition, locating the fuel test valve on the engine's fuel rail, removing the black plastic cap to reveal the Schrader valve, loosely covering it with a rag while depressing the valve stem - fuel should spray out. A fuel pressure gauge connected to the test valve is more accurate.
Old 05-18-2015, 08:36 AM   #3
mrdoiturself
It has 88000 miles on it and maintenenace has been kept up to date. Have not done plugs because they are so hard to get to in this car. That said they all seam to fire and it runs fine once started. Today I actually drove it a few miles stopped to get gas and then it didn't want to stop. I set the key to run for a bit the turn it and it starts.
Old 05-18-2015, 08:57 AM   #4
The engine didn't want to stop or start? A key to communicating on public message boards is proof reading posts (I have to proof read every one of my replies for spelling, grammatical errors, etc).
Hard starting may be a fuel issue as I have the same engine in my L300 and plugs are good for 100k miles. Instant starting in summer and winter, when everything's just right. If this is a fuel issue, the better fuel test is to use a fuel pressure gauge with 53-59 psi expected. A strong fuel spray depressing the fuel test valve. Autozone may have f/p gauges for loan - call and check for availability. Maybe a simple throttle body cleaning? The throttle plate has a strong internal return spring so more force is needed to prop open the throttle plate for cleaning. Be sure all intake air tubing and clamps are secure to prevent vacuum leaks between the maf sensor and throttle body.
Old 05-18-2015, 10:47 AM   #5
billysvue
Originally Posted by mrdoiturself View Post
... and then it didn't want to stop. I set the key to run for a bit the turn it and it starts.
It wouldn't shut off/ was dieseling? when you tried to turn off the ignition when you stopped for gas?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-18-2015, 12:56 PM   #6
mrdoiturself
No it intermittently won't start. It cranks turns over but doesn't start. If I leave the key in the run position for a half minute then start it it fires right up.it doesn't seam to have anything to do with the weather or gas level as it has done this in multiple situations.
Old 06-01-2015, 11:48 PM   #7
dr_phillgood
dr_phillgood is on a distinguished road
2002 VUE 3.0L
It sounds like a fuel delivery problem, but I had a slightly similar problem with the same car. It would crank and turn over like normal but would not start if the engine was hot. I had the crank position sensor changed and it always started after that.
Add to dr_phillgood's Reputation
Rate the quality of this post and help dr_phillgood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dr_phillgood is offline   Reply With Quote
Old 06-02-2015, 02:52 PM   #8
Chazberry
Chazberry's Avatar
^+1
That was my experience with my '03.
Add to Chazberry's Reputation
03 Saturn doesn't start periodically, but eventually does start Caveman1953 L-Series Tech 5 11-25-2011 09:15 PM
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 10:27 PM
Cold start fine, warm start takes a couple of tries FredM S-Series Tech 5 09-05-2008 04:03 PM
1999 SL2 Wont Start/Hard to Start in Hot Weather BlueOgre S-Series Tech 9 06-28-2007 05:36 AM
2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) mymimi75 L-Series Tech 1 08-18-2006 10:50 AM
