Old 05-16-2015, 04:31 PM   #1
Jeeprz!
Jeeprz! is on a distinguished road
Default new silla rad leaking at the drain hole
yet another issue has come up
I replaced the rad with a new silla brand during the rebuild project, and while putting the front end back together the other day I noticed fluid under the car (still on jack stands). I've ran the car a couple dozen times since getting it back together to where I could start it, and of course first thing i did was check for leaks and multiple times after the first start with no issues found.
Well now it seems to be leaking out of the drain hole which I thought that maybe the plug wasn't tight or vibrated loose since it wasn't leaking in a dozen or more other starts and runs (anywhere from 15 to over an hour run times).
I have the plug as tight as I can get it, and it still has a drip, after running the car for about an hour or so now the reservoir is down about 1/4 inch or so.
I can't return the rad as defective as I no longer have the packaging, I could order another one swap it with my current one, and send that back as defective but that would be kinda shady not to mention I would still have to eat the shipping.
I don't care about the drain hole/plug as I never intended to use it anyway, I had thought about trying to plug the hole with epoxy to seal it, or maybe find a plastic rod that will fit in it then melt the end over with a soldering iron, but I don't know if it would then just leak out of where the plug itself screws in.
I'm not a fan of "stop leak" type fixes, but I think I've read on here that you can use black pepper or ground ginger and that they did that at the factory?
Any thoughts would be appreciated-
"Officer, turning on your lights and siren just because you lost the drag race is just poor sportsmanship."
"Turtle" the Green 1998 SC2 Auto DOHC 160k that doesn't burn any oil!
Add to Jeeprz!'s Reputation
Rate the quality of this post and help Jeeprz! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeeprz! is offline   Reply With Quote
Old 05-16-2015, 04:53 PM   #2
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Re: new silla rad leaking at the drain hole
Where did you buy it?
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 05-16-2015, 04:59 PM   #3
Jeeprz!
I bought it off Amazon, thanks to member 2000SL2SC2!
2000SL2SC2 sent me a PM after I had posted about my old one leaking at the trans line fittings, it's not listed as a Silla but as 2000SL2SC2 told me that's what came and that's also what I got.
$49 delivered
http://www.amazon.com/Shepherd-Auto-...ype=automotive
Old 05-16-2015, 06:25 PM   #4
Steve44
Steve44 will become famous soon enoughSteve44 will become famous soon enough
Steve44's Avatar
1999 SL1
OEM "Style"
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-16-2015, 06:55 PM   #5
billysvue
WTH with Pepper and Ginger? This isn't culinary school, ya dillweed!
Thoughts aside
.........remove the drain plug, insert a tapered wooden dowel into the hole, wrap drain plug 3 times with teflon tape, reinstall drain plug. AND/OR install a new O-ring on the drain plug, if so equipped.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-16-2015, 07:37 PM   #6
Ginger tablets were used, think it was more of a conditioner for the head gasket rather than be a form of stop leak.
Going by the luck I had with radiators, I'd trust one from a JY before I trusted a knockoff radiator (unless its one of the rare all aluminum ones).
Old 05-16-2015, 08:53 PM   #7
There is an o-ring on the plug. Back it out and re-close it. Do not over tighten or it will leak.
Silla drain plug with o-ring. http://imgur.com/0IoYi6T
Front seal oil drain hole Lilchief S-Series Tech 1 03-26-2013 04:42 AM
Evap Drain Hole SaturnIONSLVUE Ion Tech 1 05-13-2010 03:01 PM
stripped auto trans drain hole bhmet S-Series Tech 3 09-20-2009 09:32 PM
Water drain hole in OE muffler? bryan_johnson S-Series General 3 04-15-2005 11:29 AM
stripped threads on block coolant drain hole geartooth94 S-Series Tech 13 01-05-2005 12:12 AM
