Old 05-16-2015, 08:31 AM   #1
tfgorman
tfgorman has a spectacular aura abouttfgorman has a spectacular aura about
Default No electrical / power at all
99 Sl manual sohc no ac power steering 230000 miles.
No electrical / no power at all. Nothing in car electrical works at all. With key on or off. Will not start obviously. No headlights, dome lights, nothing.
I have checked the ign fuses and all good. Besides that haven't really checked anything else.
Car was working fine, then went in to start it yesterday. I had power then turned the key, then everything went black. I tried turning the key back and forth a bunch of times but nothing, completely black. There was one time when I turned the key in the 100 times of turning the key back and forth that I had a short 2 seconds of power where the instrument panel lit up, but that was it. Completely black besides that.
Makes me think ignition switch since it seemed to happen as I turned the key.
What should I do? Any suggestions?
Add to tfgorman's Reputation
Rate the quality of this post and help tfgorman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tfgorman is offline   Reply With Quote
Old 05-16-2015, 08:59 AM   #2
billr
Default Re: No electrical / power at all
Check/clean cable connections to the battery, both + and - (ground). Follow the ground cable down to where it attaches to the engine, make sure that is tight and cable is intact. Do you have an electrical multimeter?
Add to billr's Reputation
Old 05-16-2015, 01:10 PM   #3
tfgorman
Yeah I have a multimeter. I will start checking some stuff out.
Old 05-20-2015, 01:45 AM   #4
tfgorman
Ended up being a bad ground connection. Was quick and easy to find once I started looking around.
Thanks for the help. I was stuck on it being the ignition, since it occurred at exactly the same time as turning the key. But just a coincidence I guess.
Old 05-20-2015, 07:40 AM   #5
Ignition switch was extremely unlikely, since components that are not dependent on the ignition switch were affected as well.
Add to madpogue's Reputation
Loss of electrical power saturn95 S-Series Tech 4 04-02-2014 08:19 AM
I need more power! (electrical that is) Nightwalker Astra General 15 06-14-2010 01:24 PM
99 sc2 has no electrical power at all? scum1 S-Series Tech 7 05-10-2010 12:19 PM
92 SC2 no electrical power boydp S-Series Tech 1 03-27-2009 05:00 PM
electrical power loss Zorak S-Series Tech 5 10-19-2005 07:17 PM
