Old 05-14-2015, 03:29 PM   #1
bryanr72
bryanr72 is on a distinguished road
2000 SL2
Question Need some assistance, plz. Adding tail lights to an SL2
I searched before I posted this, and I don't know where else to look.
I'm going to drill a .5" hole on the inside on my tail light assembly...up on the side where the reflector is. I'm going to install a 194 bulb, and wire it to my tail light wire. I've been looking on the forums to find a wiring diagram for the back end of an SL2.
Can anyone point me in the right direction as to where I can find the wiring diagram?
I appreciate the help.
-Bryan
-Bryan
2000 Saturn SL2
5 Speed
116K Miles
Blackberry
Add to bryanr72's Reputation
Rate the quality of this post and help bryanr72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryanr72 is offline   Reply With Quote
Old 05-14-2015, 05:55 PM   #2
robb_sc2
robb_sc2 is on a distinguished road
Default Re: Need some assistance, plz. Adding tail lights to an SL2
are you adding another lamp to the tail light circuit? doesn't it already have a tail light?
Gold 1999 SC2 ~385k Kms
Add to robb_sc2's Reputation
Rate the quality of this post and help robb_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robb_sc2 is offline   Reply With Quote
Old 05-14-2015, 08:01 PM   #3
bryanr72
2000 SL2
Wrench Re: Need some assistance, plz. Adding tail lights to an SL2
I am adding a new light to the side of the brake light assembly. If you look at the car from the side, the front side marker has a light in it, but the reflective part of the tail light does not. Plus, if you look at the rear of the car from a distance, Saturn didn't make a very big area that the tail/brake light occupies.
So, maybe it will make the whole thing have a little more light.
I'm getting new brake lights, so I'm gonna try this mod on my old ones.
I just need the wiring diagram.
-Bryan
2000 Saturn SL2
5 Speed
116K Miles
Blackberry
Old 05-15-2015, 09:06 AM   #4
GM/Saturn doesn't understand how to do a proper service manual like most other manufacturer's do.
Brake lights - light blue.
Reverse - light green.
License plate/parking lights - brown.
Verify with the current harness before cutting anything...lol
With how overloaded the stock wiring is from the factory I wouldn't add anything but led's to the existing lighting.
Old 05-15-2015, 11:28 AM   #5
bryanr72
2000 SL2
I haven't looked, but what color wire is the tail light? I'm assuming all the ground wires are black?
I am going to use LEDs. As a matter of fact, I finally found a electronic flasher to support LEDs. AND...they have finally started coming out with LED headlights. I bought a set of 9005s & 9006s from CREE. Each bulb puts out 3200 lumens, & they are all 6500K. Even the 880 fog lights are 3200 lumens & 6500K.
-Bryan
2000 Saturn SL2
5 Speed
116K Miles
Blackberry
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 03:33 PM
Vue w/no tail lights, park lights, plates, instrument panel zxnismo Vue Tech 7 01-28-2014 04:16 PM
No dash lights/ Tail lights/License plat light jmelvin L-Series Tech 6 02-20-2012 02:41 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 02:08 PM
adding strobes to the turn and tail lights tsc Ion General 10 03-06-2006 09:37 PM
