Old 05-05-2015, 10:27 AM   #1
jaredthefail
jaredthefail is on a distinguished road
1997
Dizzy 97 sl2 ignition problem
I have a 97 sl2 that has had a whole bunch of ignition problems that I narrowed down to the switch. when it hit ~205000 miles, it started to blow the ign 3 30 amp Maxi fuse under the hood so my dad threw parts at it to try to fix it, but the main parts were to do with the starter itself.
I went in under the kick panel and steering column the other day and found that the black ground wire coming out of the switch was completely fried. the insulation had melted completely off, so I went and replaced the switch with an a.c. delco one and cut the wire that was fried and grounded next to the interior fuse panel.
this fixed the problem for about a week, but the fuse blew again yesterday some time. It's not exactly when you turn the car on that it blows. It happens when you've been driving for a while.
I am completely out of ideas on what the problem is besides the fact that it is the wire burned all the way up to wherever it is grounded.
I love this car and plan to drive it as long as she'll run, but I really don't know what to do anymore so any ideas would be very appreciated
thanks!
Add to jaredthefail's Reputation
Rate the quality of this post and help jaredthefail reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jaredthefail is offline   Reply With Quote
Old 05-05-2015, 12:43 PM   #2
Default Re: 97 sl2 ignition problem
You do not actually need that black ground as all it does is set off the key minder dinger. Your problem is probably the green wire on the other side of that circuit also fried the switch in the lock mechanism and now grounding the fuse through the black ground. Go into my photo galley and all the sheets for the ignition switch drawing is in there and you will see what exactly is on that IGN-3 circuit. Start isolating parts until you find the problem. I would start by opening that black wire ground.
Old 05-05-2015, 03:37 PM   #3
jaredthefail
1997
so if I cut the green wire too it should get did of the problem? I actually cut the two wires in the door a while back because it would chime any time the door was open.
thanks,
Jared
Old 05-05-2015, 06:09 PM   #4
Look at those drawings and get the 2 that go to the key minder circuit, 1 is that black ground. That should get rid of the problem but you will know if it takes out another fuse and then you start tracing and inspecting wires.
Old 05-05-2015, 06:46 PM   #5
jaredthefail
1997
I'll do that right now. thank you for the idea and the pictures
just one last question, is the burned wire that I cut something I should worry about? like I said, the insulation is completely burned off and I'm a bit worried it's melted onto another wire or two
Old 05-05-2015, 07:32 PM   #6
That is what you need to trace down by opening up the loom as that is usually what ends up blowing fuses. Do that first. Get rid of that old ground wire. Once you do that it all might be fixed.
Old 05-05-2015, 07:39 PM   #7
jaredthefail
1997
Sounds good. I went in there and removed the kick panel and cut the green wire, but I don't know if I'll be able to work on getting the ground wire out until Thursday.
But thanks for all your help. I see why you're so well known on this site.
thanks again,
Jared
Old 05-05-2015, 07:46 PM   #8
That ground wire has caused wire damage and the loom will open up so you can root it out. It is likely the green wire was not being a problem unless it was in contact with the melted old black one.
Old 05-11-2015, 10:51 AM   #9
jaredthefail
1997
the other day I went and replaced the ignition switch where the mechanical part turns to electrical and I also cut the burned black ground wire up to where it connects into another three packs of wires, but the ign 3 fuse keeps blowing in the under hood fuse box.
the weird part about it is the fact that it happens after I've been driving for a while. it also throws a p0401 side when it does blow and a bunch of stuff stops working.
also, what is on the other side of the interior fuse panel?
thanks
'03 Ion QC ignition problem. EugenetheJeep Ion Tech 1 09-04-2009 05:59 AM
Ignition problem icemom S-Series Tech 2 09-08-2008 05:58 AM
Ignition problem! SaturnManiac S-Series Tech 11 07-29-2008 09:54 PM
ignition problem Mr Bhp Ion Tech 3 11-26-2007 12:52 PM
Ignition Problem xxtelevatorxx General Saturn Discussion 0 06-12-2006 07:45 PM
