Old 04-16-2015, 08:29 PM   #1
emilmata
emilmata is on a distinguished road
Question clock spring? where to buy?
hey guys i have a 1999 Saturn sl 1.9 sohc and i need a new clock spring. i tried my local parts store and they dont have any. i was wondering if u guys know where to buy one (im going to call the junkyard tomorrow) but if u guys know of anywhere or have one i can buy (through paypal of course) please let me know. thank you
Add to emilmata's Reputation
Rate the quality of this post and help emilmata reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emilmata is offline   Reply With Quote
Old 04-17-2015, 10:35 AM   #2
emilmata
Default Re: clock spring? where to buy?
Found one at the local Junk Yard for $35.00 Also if any one comes across this post and needs to know the alignment procedure you:
THIS IS FOR A 1999 Saturn SL
1) Gently rotate the clock-spring clockwise with the yellow tab until you feel slight tension.
2) Gently turn clock spring counter-clockwise (about 5 times) until slight tension is present.
3) Gently rotate clock-spring 1 and 1/2 turns clockwise (so in the case of 5 revs it would now be 2.5 revs) clockwise.
4) Rotate smallest distance required to align yellow tab
5) install yellow tab. Use tape if tab is not available.
Old 04-17-2015, 12:42 PM   #3
JY is your best place to get them as long as the air bag has not fired on either side.
Old 04-18-2015, 05:34 AM   #4
emilmata
Thanks OldNuc for the replay. The air bags didnt go off, my dumb***** decided to frely spin the wheel when i had the rack disconnected not reliazing i would damage the clock spring, but i just reinstalled the one from the junkyard today and it works perfect (after i did the proper alignment of course)
Old 04-18-2015, 07:50 AM   #5
Well, at least it was a relatively low cost learning experience.
clock spring dorisSL S-Series Tech 25 05-22-2017 07:05 PM
95 Clock Spring replacement wi111y S-Series Tech 7 06-27-2013 06:11 PM
clock spring help, where to buy? taatman S-Series General 5 03-18-2013 06:02 PM
Must replace Clock Spring in my 03 Vue JimVue03 Vue Tech 3 11-16-2010 04:58 PM
Looking for 99 SL2 Clock Spring cburg S-Series Tech 2 04-07-2010 02:39 AM
