Old 04-06-2015, 06:54 PM   #1
joelkillspeople
joelkillspeople is on a distinguished road
Default 2002 SL2 - low beam not working, but bulb isn't burned out!
Hey all. I am having a problem with my mother-in-law's car. She has a 2002 SL2 manual 5-speed.
Her driver's side low beam stopped working. I have investigated the bulb, and it appears good. I also checked all the fuses, and they appear to be good. The most curious part: both high beams work just fine, along with the daytime running lights.
Can anyone give me a hint as to what I should be looking for? I checked voltage on the low beam, and it doesn't appear to be getting any voltage.
Thanks!
Add to joelkillspeople's Reputation
Rate the quality of this post and help joelkillspeople reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joelkillspeople is offline   Reply With Quote
Old 04-06-2015, 07:26 PM   #2
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
Default Re: 2002 SL2 - low beam not working, but bulb isn't burned out!
Have you checked the fuses, would have to look at the wiring diagram, does the car have day time running lights, can look on the computer at work tomorrow.
Add to 54packman's Reputation
Rate the quality of this post and help 54packman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
54packman is offline   Reply With Quote
Old 05-15-2015, 04:35 PM   #3
joelkillspeople
Ok, I fixed it. The wires going to the bulb had broken and rotted through. I replaced them and soldered some new wire in, and everything's back to normal! Thanks for your help.
Light bulb behind the Odometer burned out.... aliensporebomb L-Series General 8 08-20-2014 07:43 PM
Does a burned out Check engine bulb trigger the wrench? chevy57 L-Series Tech 2 02-23-2009 01:57 PM
Can a burned out light bulb cause other problems? StarLady S-Series Tech 5 06-24-2008 09:19 PM
How to replace burned out bulb for seat heater button? Tyrone Vue Red Line 1 12-14-2007 04:25 PM
Side Fender Bulb Burned Out Azrael_02 Aura General 3 03-16-2007 12:59 PM
