Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 04-01-2015, 11:48 PM   #1
nick.evans
nick.evans has a spectacular aura aboutnick.evans has a spectacular aura about
Question ECTS Replacement Part Question
My 99' SC1 has been idling really hot in traffic lately, and after digging around online one of the recommendations was to replace the ECTS. It sounds like it is typically an inexpensive highly recommended 'repair' anyways, so I thought I'd try it out. I reviewed the two how-to guides in the How-To Library (1, 2)
as well as watched a video on the procedure. Regarding the actual task, I feel ok. What I'm wondering is whether I will have all the parts I need.
I found what appears to be the connector replacement here. But it only looks like a connector. Would I still need a new sensor itself? The bit I read made it sound like the connector would fail/corrode and that was what needed replaced most often, but should I be looking to replace the piece that actually threads in with the 13mm socket, or is just the connector sufficient?
I appreciate everyones assistance.
Add to nick.evans's Reputation
Rate the quality of this post and help nick.evans reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nick.evans is offline   Reply With Quote
Old 04-05-2015, 12:56 AM   #2
cjhaddox
cjhaddox is on a distinguished road
Default Re: ECTS Replacement Part Question
I ordered mine online off of ebay
Add to cjhaddox's Reputation
Rate the quality of this post and help cjhaddox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cjhaddox is offline   Reply With Quote
Old 04-05-2015, 07:13 AM   #3
The stock resin tipped ECTS cracks, fails and allows coolant to seep through it which then corrodes and destroys the connector. The replacement brass one can still fail but as far as I know it doesn't crack open to also kill the connector.
If your ECTS has cracked replace both the ECTS and the connector; otherwise just the ECTS unless symptoms continue.
clutch part replacement question herostatus S-Series Tech 4 02-23-2013 01:35 PM
A/C suction hose replacement part for SC2 - question KSabo S-Series Tech 6 03-16-2012 04:58 PM
Saturn Body replacement part question john02sl2 S-Series General 2 04-19-2010 05:56 PM
ECTS Replacement? Is wiring different for new ECTS? arunsam3000 S-Series General 4 01-13-2009 03:45 PM
ECTS replacement question JS593 S-Series General 31 10-31-2005 08:16 AM
