Old 04-01-2015, 12:11 AM   #1
SeanW
SeanW is on a distinguished road
Default 2002 L200 custom shifter help
Hello,
So I recently purchased a manual 2002 L200 and am wanting to put a custom shifter but I cannot find a reasonably priced non-threaded adapter to be able to screw on a custom shifter. any links to adapters that work would be helpful!!!
Add to SeanW's Reputation
Rate the quality of this post and help SeanW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SeanW is offline   Reply With Quote
Old 04-02-2015, 10:30 PM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: 2002 L200 custom shifter help
Unfortunately, the shift knob appears to be permanently attached to the lever. If you don't like the appearance of the standard knob maybe you could make a small cover of leather or fur or ???.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-17-2015, 09:49 AM   #3
Zsolt
Zsolt is on a distinguished road
Zsolt's Avatar
I have the same car just an 03. The shifter is not permanently attached. However the end of the shifter (the metal) is a rough cross diamond pattern to give it texture. The shift knob itself on the inside is made out of a durable plastic that attaches to the rough metal via those etchings with friction. You can simply pull it off. Though I don't recommend it as every time you do so the plastic wears away and eventually it'll just twirl on top of the metal. I've searched endlessly for a new knob that will fit, but after a year I've given up. Just short of ripping out the core of the OEM shifter and attaching it to an aftermarket one, or just custom making one, I'm out of ideas. Good luck though!
Add to Zsolt's Reputation
Rate the quality of this post and help Zsolt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zsolt is offline   Reply With Quote
2003+ L200 custom/aftermarket headlights? Zsolt L-Series Tech 4 06-09-2014 09:15 PM
2002 SC2 Custom Spare Tire Amp Rack Meowth S-Series General 3 06-17-2011 03:53 PM
Should I put a custom stereo deck in my 2002 SC1? yamas S-Series General 30 01-23-2008 09:44 PM
Custom short shifter group buy! bc3tech Ion Mods 46 02-14-2007 08:34 PM
SPS shifter w/ custom boot and knob SleeperSC2 Classifieds 5 11-08-2003 12:19 AM
