Old 03-24-2015, 09:37 PM   #1
jadenrosen
jadenrosen is on a distinguished road
2004 L-Series 2.2L Sedan
Default L300 Check Engine Light
Hey this is my first post here, I just bought my Saturn its a 2004 L300 2.2L.
My question (I love the car by the way) is, the low coolant light came on, then would shut off later, and then later the service engine soon light came on and the coolant turned off, does low coolant ever turn the light on or should I be worried?
Its only been a day since I bought the car, so it's not ongoing yet... I'd just rather be safe than sorry. It may be first self bought car jitters lol.
But here's hoping!
Add to jadenrosen's Reputation
Rate the quality of this post and help jadenrosen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jadenrosen is offline   Reply With Quote
Old 03-25-2015, 05:13 AM   #2
thepat
thepat has a spectacular aura aboutthepat has a spectacular aura about
Default Re: L300 Check Engine Light
Have you checked your coolant level? I have a very slow leak and when it gets close to the minimum in the coolant tank, the light will come on, but shuts off when the car warms up and the pressure in system builds causing more coolant to be in the tank.
As far as the check engine light, get yourself a cheap OBD II scanner like this:
http://www.amazon.com/Autel-MaxiScan...obd+ii+scanner
and get the code that's causing the light.
Add to thepat's Reputation
Rate the quality of this post and help thepat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thepat is offline   Reply With Quote
Old 03-25-2015, 08:40 AM   #3
Russet
2002 L-Series 3.0L Sedan
But here's hoping!
That tells you your low on coolant. I seen my 03, 02 Saturn L300 do the same warning light. It's is natural during the course of driving coolant does evaporate out and you have to fill it. Now if you fill up your coolant and withing that week the light is back there might be more serious problem like head gasket leak. But if you fill it up to the normal level and drive and nothing happens then it was just low on coolant. For the Service light to come on you will need a Scanner to read the code to know what the Error code is and post it on here.
Add to Russet's Reputation
Old 04-17-2015, 05:15 PM   #4
Rattler14
Rattler14 is on a distinguished road
Rattler14's Avatar
2003 L-Series 3.0L Wagon
My OBD II reader I bought off of Amazon and is bluetooth compatible with my smart phone. Total of $25 and works like a charm; money well spent!
Add to Rattler14's Reputation
Rate the quality of this post and help Rattler14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rattler14 is offline   Reply With Quote
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 04:38 PM
What is Saturn's equivalent of "Check engine light"? Smog won't pass bulb check. harmono S-Series General 5 02-28-2012 10:17 AM
check engine light and coolant level light stuck on saturn/chev S-Series General 13 11-22-2011 08:20 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
L300 V6 Check Engine light Razzor19 L-Series General 4 10-30-2008 03:27 PM
